Lens titles/descriptions typically list the maximum aperture(s) that the lens is capable of. In the case of a constant aperture lens that will be one value - such as f4, f2.8 etc... This is the case for all prime lenses (those of a single focal length) and for high-end zoom lenses which will retain the same maximum aperture through their whole focal length range. Variable aperture zoom lenses are ones which have an aperture with reduces as the lens moves through its focal range - for example a 70-300mm f4-5.6 lens will have a maximum aperture of f4 at the 70mm but only f5.6 at the 300mm end of its focal range.
The minimum apertures capable by lenses (ie the biggest f numbers) vary, but are generally only stated in the lenses tech specification, normally found on review sites and, of course, the general spec sheet on the manufacturers website.
