Canon 6D flash sync speed
jjd228
United States
The max flash sync speed of the Canon 6D is 180. But when you leave the camera at the default exposure increment setting of 1/3 stop, you can't even hit a shutter speed of 180. It goes from 160 to 200. This happens if you use off camera flash or when you have a speedlite attached and have it in HSS (high speed sync) mode. Once you disable HSS you max out at 180 and can't go any higher. I guess I'm just wondering why I can't stop at 180 when using off camera flash. I can change the exposure increment setting to 1/2 stop and then 180 is available to me, but do I want to do that? What's going on here?
Thanks!
