Yes, but there are converters for this. I just can't remember what the style of connections are.
The converters are junk, even the ones Canon made. No auto focus (obviously), and no aperture control whatever. In other words, you have to focus manually (which can range from relatively easy to extremely difficult, depending on the situation) and then stop down the lens manually (making it anywhere from no more difficult to impossible to frame), and use it that way.
Then you have the focal plane issues involved. (This is a WAY oversimplification of this, for you lens geeks, I apologize in advance)... basically, because of the introduction of the adapter between the body and lens (since one is a "innie" and one is an "outie" this means that infinity focus will only be possible on certain lens/adapter combinations... Canon EOS cameras use an extremely short flange to focal plane setup (which, by the way, makes the Nikon lens to Canon body adapters work surprisingly well). Due to the construction of the FD lenses, you have to use an adapter which has additional optics built into it, and you run into the same issues that you get with a teleconverter... a slower lens with degraded image quality.
You end up with a slower lens that can't autofocus (naturally), that can't use auto aperture and must be stopped down manually on a camera that doesn't have a ground glass focus screen that is designed for manual focus.
Technically, the converters with adaptive optics "work", but in practice they are useless.
If you want to try one, they are at least cheap:
FD to EOS adapter
Me? I wouldn't waste the money.
The ones without adaptive optics will not allow infinity focus at all, so if you get one you NEED to make sure it has the adaptive optics (be prepared to lose a couple stops and have seriously degraded image quality).
So... IMHO... forget about it, they (the FD lenses) won't work in any practical sense.
