Canon R7 and RF 100mm focusing problems
davholla2 1
This combination worked fine this was in flight
5T2A3059-CR3_DxO_DeepPRIME -1Hoverflyv3 by davholla2002, on Flickr
But now focusing is really hard - stationary photos are harder than the above- I haven't changed anything - or rather hadn't - I have now to fix it without success.
The limiter on the side is not the problem because I changed it
Any ideas?
Can you give an example of the focusing issue?
Either description of what's happening or a photo. Setting (good and bad focusing) would also be helpful in diagnosing a possible issue.
Yes it hunts a lot more than before - I would have been off using my Canon 550D (if it hadn't died) and a 60mm lens.
The settings didn't change at all sorry not to give more information.
So from what I can see this does seem to be an issue with the R7.
I can't find a one solution fits all type of answer though. I'll link a couple of threads (Non TPF) below that may help.
https://www.reddit.com/r/canon
Thank you - it's very weird that it worked fine and then didn't. If no one replies soon I will try a factor reset.
