- Joined
- Nov 27, 2011
- Messages
- 7,716
- Reaction score
- 4,577
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
....Conclusion: There shouldn't really be any technical reason why it is more useful to edit a RAW than to edit a jpeg after first converting it to 16 or 32 bit.
The technical reason is that the camera JPEG processing software isn't adequately capable of rendering the photographer's intent and, after the fact with the raw data discarded, it is then usually impossible to realize the photographer's intent from the JPEG file.
In a response further back in this thread you said this: "And if you are thinking about color and light in the field (which you should be), then you shouldn't need very much flexibility. The out of camera jpeg should already be pretty much where you want it, and whatever minor (10-20%) corrections you may want to do will not be sufficient to cause visible color posterization.
There are tons and tons of settigns in your camera for setting up a proper white balance. There's custom compensation, there's pre-set WB for different standard lighting conditions, and there are options to calibrate using cards in the field. You have all the tools you need, most of which only need to be set once for an entire shoot."
This is where you're completely missing it. If you can coax a JPEG from the camera software that is close to the photographer's intent, and I grant that this is in limited circumstance possible, then I'll agree that a camera JPEG once converted to 16 bit can tolerate light repair and remain serviceable (wince). The problem is that what you're suggesting as an approach to taking the photo isn't workable over a sufficient range of conditions -- at least not for me. And those tons and tons of settings available in our cameras are sub-crude and entirely inadequate to the task given what we know is possible once we have the raw file. So in part it's a case of because we can. We're always going to be pushing to go as far as we can. Using the camera processing software is like tying one hand behind your back, then tying your shoelaces together and trying to run.
I am curious as to how I might be proven wrong, in reasonable situations where you didn't completely fail your photo?
You asked for a challenge, here you go. I took this photo:
I'm happy with that photo. That's what I saw (photographer's intent) and what I expected to take away when I clicked the shutter. I am using a Canon camera and the day I unboxed it I set those tons of settings to null and the picture style to faithful as you have suggested. Here's the camera JPEG for that image:
And here's a link to that JPEG at full-res so you can download it and go to work processing it: Cannon_wetland The processing goal of course is to realize the photographer's intent and produce the same image I produced from the raw file. You can post it back here when you're finished.
You may want to argue that I could have used those tons and tons of camera settings to coax the camera software into producing a result closer to my intent and I might have better luck then trying to repair the JPEG. I know better -- not in lighting conditions like this.
Your very limited proposition that a JPEG once converted to 16 bit can tolerate light repair is valid but it makes me wince. I've never seen a camera processed JPEG that I couldn't repair and improve. I spent years chasing after this very proposition since I've always wanted a camera to carry with me everywhere. When digital cameras became shirt pocket size I started buying them and using them in precisely this way. They only produced JPEGs and I would work to get the best JPEG possible and then repair it in Photoshop. I went through 1/2 a dozen of those cameras constantly frustrated. I'd buy one and then when it bit me (impossible to repair JPEG and I knew a raw file would have worked) I'd ship it off to a niece or nephew and eventually get another one. I finally compromised on a slightly larger camera that would save raw files. I'm happy now and my production rate has soared with no more frustration.
Joe
