Proper lens handling is foremost. When you change lenses, beware of any airborne dust. Don't allow any dust particles to enter the open camera body. Same for the back end of lenses. Keep them covered at all times. Do not touch the rear element or the mirror. Keep your fingers out of the light box.Which is the best for cleaning lenses and filters, soft brush, cloth and lens cleaning solution or both?
What should we not do?
What he said. A CPL will cost you two full stops of light and can cause odd light conditions on a photograph depending on how it's oriented. If you feel compelled to leave a filter on a lens (most people don't, I frequently do) a CPL is not the right choice. Use a clear UV filter or something that will not degrade a photograph when you don't really need it.I don't think you should leave a CPL on your lens all the time. Put it on only when you need it for the conditions.
What to use and how to use it depends on what you're trying to clean off. A little dust? Lots of dust? Fingerprints? Water? Water spots?
To the OP, just to let you know this argument about filter verses no filter is older than the argument Nikon vs Canon, Mac verses PC, light beer verses good beer. So yes there are two sides to this discussion.
Personally I am a big believer in keeping a filter whether a polarizer or skylight or UV filter on my lenses at all times. As John mentioned it's best not to need to clean the lens so my thoughts - I can clean and or replace a filter easier than a lens. Over the years I have had to replace many filters and am always glad I didn't have to replace the lens. ( I try to shade my lens from direct light sources IOWs the whole no filter argument)
To the original question:
1) hand blower
then
2) brush
if work still needs it
3) micro cloth
and if work still needs it
4) (finger print) lens pen
5) solution onto lens tissue
my understanding is that the lens coating is a bio film any excessive moisture can lead to fungus growth never put the liquid solution onto the lens always onto the tissue first.
.............my understanding is that the lens coating is a bio film any excessive moisture can lead to fungus growth never put the liquid solution onto the lens always onto the tissue first.
A CPL filter has two elements that rotate in a mount so that the direction of the light can be polarized. If you leave it on the lens all the time you are going to have to adjust it every time you take a photograph if the light changes. One position of the CPL does not work all of the time, you have to take the time to adjust it for the best effect.What you say makes sense to me that the light will be reduced, but the compensation for that would be better looking skies and clouds, greener grass and only reflections on water and similar we would want. Am I right with this thinking?
