I see some possibilities here, but I don't think it's quite 'there'. First off, the perspective is a little skewed, probably because your camera was quite level and square with the scene; if you can access to Photoshop CS3 or newer, the distortion filter can help correct that. As well, it's a bit over-exposed; I don't see any pure white, and I suspect that the background building is supposed to be white. Lastly, I'd crop just a bit of the foreground away, just enough so that we don't see that ridged track beside the fence shadow end.
If this is the type of photography that you really enjoy, I would strongly recommend the purchase of a good incident-capable light meter such as the Sekonic L-358 (there are lots of others, many less expensive models as well). Also, when composing, concentrate on keeping everything straight and level; use the grid lines in your viewfinder to align the verticals & horizontals in the scene.
