shingfan
- Joined
- Dec 29, 2006
- Messages
- 569
- Reaction score
- 0
- Location
- Toroto, ON
- Can others edit my Photos
- Photos OK to edit
if i have two layers on one image, how do i resize one layer without affecting the other layer? thanks
you can easily align linked layers horizontally or vertically
assuming you use CS2..............
they must be linked first using the layer control window. Select the layers you wish to align using shift or control and left click.
then click the link icon ( it looks lik 8 on its side)
Layer>Align and select the edge or centre you wish to align by.
one point to note - if the layers are different sizes then make sure the active layer is the largest one, normally the background - otherwise those larger layers will be pulled to align with a smaller layer and can leave empty gaps in your image.
You'll know what i mean if it happens to you!!!
