anubis404
- Joined
- Apr 5, 2008
- Messages
- 955
- Reaction score
- 0
- Can others edit my Photos
- Photos OK to edit
Your choice of lenses above tell a different story.
Huh?
I thought the same thing too, you've got some pretty nice lenses..Huh?
Take the Canon 5D2 for example, it has a full frame sensor which allows it to capture more of the scene. This is generally desirable for landscape photographers trying to maximize FoV (field of view) coverage and to get the most out of their lenses like ultra-wide angles. The trade off is that you have slower shutter speeds (3.9 frames per second) than you would have with a crop sensor camera like the 50D (6.3 frames per second). It's view finder also has 98% coverage whereas the 50D's only has 95%.Hello,
Can someone explain why some cameras are preferred for landscapes, while others for action, and others for portraits...etc? What is differentiating certain cameras from others to do a certain job "better"?
Can you post a link the God straps? I would like to check those out, they sound interesting.
Easy there sunshine....... I love my little $300 35mm lens.![]()
Just as a "for instance"... why choose the 80-200mm Nikkor over the gold standard 70-200mm? The OP did state that price was not part of the consideration.Huh?
Okay, you got me, so I got the 55-200mm lens along with the 18-55mm kit lens with the original purchase and they have become some nice paper weights. But I then got the primes before the "big boy" zooms.I bet if we look at your list, you will have a few useable zooms before the primes.
Ummm, that would be for YOU. The OP had already stated that cost was not an immediate concern.Because price was an issue. I could barely afford the 80-200, and even if I could afford the 70-200,...
Since I happen to use Photozone.de as my first port of call for lens reviews and will only use the Verdict as a basis for my comments in this instance, the consensus is quite apparent in the grand scheme of things from many other sites that do lens reviews of the superior 70-200mm. The fact that it is not in your price point is irrelevent..... a slightly better AF system and VR are not worth twice the price. As I said before, I would've invested that money in better glass. If my info is correct, the 70-200 and 80-200 are optically the same.
Verdict
Despite its age the Nikkor AF 80-200mm f/2.8D ED is a great lens both mechanically as well as optically (assuming you can get a good sample). The resolution is on a very high level throughout the zoom range and neither distortions nor vignetting are big issues (on an APS-C DSLR). CAs can be visible at times but the problem isn't overly pronounced. It is a joy to use this lens and the relatively large aperture provides some creative potential in the convenient package of a zoom. The comparatively low price tag is also a good argument to have a deeper look into this interesting option ... unless, of course, you can afford the AF-S 70-200mm f/2.8G IF-ED VR.
There is a reason for the difference in cost between those two lenses.
