goodguy
- Joined
- Dec 5, 2012
- Messages
- 5,555
- Reaction score
- 1,121
- Location
- Toronto Canada
- Can others edit my Photos
- Photos OK to edit
haha, I suppose that means that the Nikon Coolpix A is also better than the new Canon 7DIIIt's the newer version of the previous best d7100.
wow, my old d7000 is considered overall better than the new Canon 7d mark II
It also has a different microlens setup so that the integrated 18mm f/2.8 could be mounted closer to the sensor to make it thinner. There's a couple other random differences as well, but yeah, at heart, it's the same sensor as the D7000.'cept I'm pretty sure the d7000's sensor does have a low pass filter. So there's one difference.
Yeah, I've seen some strange results like that. If you test it against the Nikon d3x (or S .. I'm not sure) you'll see the same type of result.
also, it's important to remember that it's ONLY a test of the sensor. Nikon's sensors in the new D3300 are pretty insanely great and the 1Dx, while a great camera, has a sensor that is getting relatively long in the tooth.Yeah, I've seen some strange results like that. If you test it against the Nikon d3x (or S .. I'm not sure) you'll see the same type of result.
The MP of the sensor seems to have a large impact on the overall sensor score
irregardless of it's actual low light sensitivity, etc
