arcooke
- Joined
- Feb 24, 2008
- Messages
- 391
- Reaction score
- 8
- Location
- Plano, TX
- Can others edit my Photos
- Photos OK to edit
So, I finally started shooting in Raw...thats one Major hurrdle...now for shooting in Manual.
Don't shoot in full manual.
It sounds like you're using the internal light metering system that's built into your camera. And it sounds like you're trying to take basically normal photos (no special effects). If that's the case then using the camera in full manual mode is slower, less efficient and likely less accurate.
Take your poinsettia photo for example. You didn't know without the camera's meter that 1/30 sec at f/4.5 was a good exposure. With the camera on full manual you had to set either the shutter or f/stop and then adjust the other until the camera meter zeroed. If you put the camera in S mode and set the shutter speed to 1/30 sec. The same meter would read the same light the same way and come to the same conclusion and set the f/stop to 4.5. In fact it may have been slightly more accurate and set it to f/4.83 (depends on the camera). It's still your responsibility to monitor what the camera's doing, but that can be done in less time than it takes to set both shutter and aperture manually. That really great shot came and went in that time.
Do it the other way: Set your camera to A mode and set the f/stop to 4.5. The same meter will meter the same light the same way and set the camera's shutter to 1/30 sec. or maybe more accurately to 1/42 sec. Again you must monitor what the camera is doing and again no one can manually set both the shutter and f/stop is the same time that they can set one of those and then mentally check off the other.
Full manual only makes sense when you aren't going to use the camera's internal metering system. That means you know the camera's meter would be wrong. That's possible. That's also allowed for by good cameras and handled with a +/- exposure comp control. On my camera that control is directly under my right thumb and immediately active. Again it's faster than full manual.
When I use the internal meter in my camera I use S or A mode and the exposure comp control and I can arrive at the best exposure answer faster and more efficiently than any one using any camera in full manual. I do use my camera in full manual when I'm using my external light meter or strobes. That's when it makes sense.
You're using the internal meter in your camera? Then use it. You're smart enough to know when the meter will be wrong? Then use the exposure comp control.
Joe
Good tips, but I'd have to disagree and say DO start learning manual mode. The priority modes should be something you learn later, after you know how each setting interacts with one another. I think it's good to know exactly what your camera is taking control of, before you let it take control. I'd say get comfortable with manual mode, then play with the priority modes.
