Desktop or Laptop?
Yeah, newegg
A 24 inch monitor is great, thats a fairly standard size monitor. You'd be hard-pressed to find a monitor these days that don't function well as everything has entered into the HD/Plasma/1080i/Superawesomeamazing thing.... I know alot of people who use a 24inch wide hd-LCD monitor and they are quite beautiful. Remember, a strong video-card is nearly as important as a good monitor. Hand-in-hand type thing.
And btw...you will never be able to tell the difference between i5 and i7, nor between 8gb and 12gb of ram.
If you Google the Internet, you will find it hard to show a single benchmark with a speed difference between 4GB and 8GB.
Multi-tasking CAN improve very slightly between 4GB and 8GB but it's very low and basically can only be seen under benchmarks (and even then we're talking mainly about the STARTUP of some games being faster because the system doesn't need to temporarily reclaim some RAM so maybe startup is 45 seconds versus 57 seconds after which there's no in-game difference.
Review - Is More Memory Better? | bit-tech.net
And I'd suggest googling the differences between i5 and i7...hell even add in i3.
The most expensive item isn't always the thing you need. If you want to save money, then I would not buy more than 8gb of ram, hell I use 4 and I have never seen a single issue nor had a desire for more ram. I'd also go with the i5 and not waste money on an i7....it get to the point where are you either going to wait 2 seconds for something to open or you are going to wait 1.5 seconds.
So you think that if I have say a 9 shot HDR or a huge 14-15 image pano shot an i5 and 8gb of ram will be plenty? I'm also starting to get into the digital painting side of things in Photoshop and if I was to have say a 36in x 24in image it would be enough to go with the i5? I'd much rather have the i7 and it be too much than get the i5 just to find out it isn't enough. I plan on only having Photoshop, Lightroom, and iTunes on the computer(plus whatever comes on it) so I won't be loaded with a bunch of other programs that'll slow down the machine.
The main reason I recommend lots of ram is because of disk caching. The OS keeps copies of recently accessed files in RAM so they don't have to be pulled off the HDD each time. This process occurs in whatever RAM is available once the programs have taken their share for actual operating memory. So, the more RAM you have, the less you need to read off your hard drive, which tends to be the slowest component in any system (even with SSD). Think if you dump a 16GB card from your camera to your hard disk... if you have 16GB of RAM free at the time, those files stay cached, and you never need to wait for them to come off the disk if you're going to be editing them right away. Your thumbnailer program won't need to read the disk to do it's business etc... Anything less than 16GB free, and you only get the speed boost on the files that fit.
Check these out. They're all IPS monitors. They can be color calibrated and represent colors far better than a TN monitor. Makes a big difference. How hands on are you with your computer? Can you swap out ram? Cards? Drives? Power supply? You might be better served getting a refurbed quad core system and adding your own upgrades. Newegg has nice deals. Get the monitor new.
Also, a nicer graphics card does make a difference when driving two big monitors. Especially at max resolution and color. One thing I've noticed about Dells is that they've been cheaping out on the hardware. They used to stock their machines with nice stuff but they've been cost cutting over the past few years, which is why it's probably better to get a basic system and stock it yourself with more choice parts.
Dell UltraSharp
Seems pretty pricey for the config you list. Laptops are portable and that's pretty much about it. A big plus for anybody that needs full powered mobile. Desktops are better in every other way. They're cheaper, more expandable and faster and better machines. Easier to type, easier to read, last longer, cheaper to fix. But you need to get a decent monitor and the ones you listed look like cheap TN monitors. Dell's Ultrasharp series are pretty well regarded IPS monitors. I'm sure you can swap the ones you have out.
I use i5. I just opened a 3872x2592, 2.48mb photo with photoshop cs5 in rougly 5 seconds (including the time to load cs5).
Like I said, your video card will play alot into how fast / smoothly it will run...more so than your processor. H
Here is a quick search about the differences between i5 and i7.
Currently, the Core i5 processor brand
makes up most of Intel's Sandy Bridge processor line. The prices of these
processors range from $177 to $216 with base clock speeds between 2.8 GHz and
3.3 GHz. Intel only offers two Core i7 products, the Core i7-2600 and Core
i7-2600K, both of which have a 3.4 GHz base clock speed. The i7-2600 has a price
tag of $294.
As you may have guessed, paying about $80
more for the 100 MHz clock speed increase between the fastest i5 and the i7
isn't a great deal. The main reason to pay this additional cash for a i7 is
hyper-threading, but this advantage will only be evident if you frequently use
programs that can actually make use of 8 threads.
For most users, the i5 is clearly the
better deal. The i5-2500 makes the most sense in my opinion, as it offers an
extremely quick base clock speed of 3.3 GHz for about $200. Of course, the value
of this is subject to change in the future as Intel fleshes out its product line
with new models
Read more: Core i5 vs. Core i7: Differences Between Intel's i5 and i7 Processors
Regardless, this comes down to how much you want to pay. If you want to buy 16gb and i7, then go for it. Personally, I wouldn't...but if you have the money and you want it, then go for it. It won't hurt you, but I dont believe it is going to truly help you either.
A test like this is actually a measurement of disk performance, not processor performance. Unless of course CS5 was cached, as I mentioned in my earlier post, then it's a test of memory bandwidth... but 5 seconds sounds uncached to me.
To compare processor performance, running things like unsharp mask, or a high radius gaussian blur, etc... will be more accurate, as they are compute intensive, but not high bandwidth. Opening a piece of software, or an image is bandwidth intensive, but easy on the processor.
I do agree though, the i5 is a great chip, and it would be hard to justify the additional cost of an i7 on a photo machine.
That memory article vituosos posted is 3 years old and totally irrelevant in 2011. 4GB of RAM would be fine for a 32bit system and your editing cell phone pics. I would recommend 16GB of RAM, it's pretty cheap now at $110 for 16GB Newegg.com - CORSAIR XMS3 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model CMX16GX3M4A1333C9
A 5770 graphics cards would still be way overkill for a Photo editing machine and is much cheaper than your
original choice.
Newegg.com - SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
Touche' :p
8gb vs 16gb? - Overclock.net - Overclocking.net
There's a more recent debate for ya, and I will still stand by 8gb of ram rather than 16.
Thank god you can buy an 8gb stick, then buy another one if and when you need it.
I guess what I was really worried about was it not being enough but that doesn't seem to be an issue does it? I can deal with it being overkill.
Are you definitely going for a laptop?
If it was my purchase, I'd go for Refurbished Dell Precision desktop. Here's one that came up in a quick search:
Precision T3500
  • Processor: Intel Xeon Processor W3530(8M Cache, 2.80 GHz, 4.80 GT/s)
  • Genuine Windows 7 Professional
  • Precision Workstation T3500 Tower Standard Power Supply
  • 500 GB SATA Hard Drive 3.5in (7200 RPM)
  • 12 GB Memory (6x2GB), 1333MHz Dual Ranked UDIMMs
  • 16X DVD ROM Drive
  • 1 GB nVIDIA Quadro 2000,Dual Monitor,2DP & 1DVI,
for $1209
The Xeon is Intel's pro series processor. They're thermally spec'd higher than the Core i series, so they essentially run cooler at a given clock speed, ensuring reliability. The Quadro video card is again a pro product, optimized for graphics applications, and not gaming, as all the other cards mentioned in this thread were.
I'd suggest poking around outlet.dell.com, they even make precision series workstation laptops. If I was spending this much on a system I'd go for something workstation class. It's like buying L glass :-), built to last you know?
Then you still have $800 or $1000 or whatever for a monitor.
