The issue is you're using a PC. Go to your local apple store, they'll be able to sort you out.
Make sure the camera is plugged into the computer and turned on. Click [Start] and then control panel, and then in Control Panel select Devices and Printers. At the top of that dialog click Add A Device and let Windows search for new devices. Sometimes that will force Windows to detect new devices that it has otherwise missed.Thanks Scott.
Check the one on the disc, it was 2.3.0 so that sounds like the problem.
Edit. Nope. Still not showing up. Using windows 7 home premium.
+1.The issue is you're using a PC. Go to your local apple store, they'll be able to sort you out.
Not even if they were free!
Are you trying to tether or just read pictures from the camera?
A card reader beats reading from the camera, hands down.
This! Unless you're tethering, there is no need to connect the camera to the PC.
It would be good to know why it isn't being detected though. Something could be wrong with the connector on the camera, the USB port or the USB cable. If possible, try connecting it to a different computer preferably using a different cable.
Well just tried plugging it into my work laptop and it shows up fine so there's nothing wrong with the camera or cable. Just something wrong with my computer.
Might just get a card reader and do it that way.
