bronzeo
First of all I don't have the perfect lighting setup. ( I am using a bounced halogen of of a white sheet and 1 florescent to mix K temp closer to natural) I will improve that as I experiment. I am an artist and find painting under this mix works great in the sense that the finish product will no doubt be displayed in a similar lighting source.
My main question is if you think that setting up a custom white balance would help me to achieve a more perfect rendition of the original art being photographed? As I flip through the presets I find an enormous difference in output, and I am not finding that the AWB is that accurate. I flipped to setting to tungsten bulb and got a better result, but was also wondering if once you set a custom white balance, if I can save that profile for later use. I'm trying to set up a controlled environment for Artwork to Print photography. I am finding it hard to control some color hues that sometimes both vivid and fragile, which makes working with PS quite a chore. It most photography this is usually not a problem to the degree that it is trying to replicate fine art. That plus lack of experience doesn't help much. Up until now AWB was fine for me..... thanks for any suggestions ( I will improve lighting as time passes)
Canon 650 with 18/135 ef-s lens
