Does this sound like a good plan? - With sample pics
Because by changing the resolution setting, but not resampling, he did not actually change the size of the image - still the same number of pixels.
The lens appears to be a Tamron 10-24mm wide angle, in Canon mount.
The important part of using these lenses, is to keep the camera exactly level, otherwise you get geometric perspective distortion. So usually a tripod is used to ensure that you have the camera angle exactly right.
Yeah I don't know the make of the Lens... but pgriz is probably right.
Yeah, tripod is a must for this. Although, you could avoid buying the big bad fast lenses, and just use longer shutters. After all DOF isn't really desirable for this kind of photography.
Charlie, did you have to correct the distortion in your first sample pic?
A little bit, but mostly because I was pretty close, and the building is so tall! But it is easy to do. Would not be an issue with most house shooting....
But if you are going to commit, I'd probably get cheaper 3rd party glass.
I would find out how much this pro gets for these pictures. Go to the houses, show him up, and then offer your services slightly (5%) cheaper.
OK, but let's step back a little. I have a T1i (1.6x crop) and a 10-22mm Canon. Interior shots at 10mm, even with completely level camera, still end up distorting the image at the edges, making object quite "thick" (never shoot people at the edge of these frames unless you want them to gain 300 lbs.). So in many cases, I would still use 12-14mm just to be sure the edge distortion didn't misrepresent the size of the objects.
So my question is, does this sound like a good plan? Pretend you were me, and had between $2,000-$3,000 to spend on a camera/lens. Is this what you would get ( sticking with Nikon )?
This is just me, but if I had $3,000 to spend and I was doing houses, I would get the D7000 and this:
http://PC-E NIKKOR 24mm f/3.5D ED
Yes, it is not as wide nor as "open" as I would like, but with the PC, you can get it all straight the first time.
I think the photo in question had the edges cropped a bit.
