cooldood127 9
- Joined
- Jul 14, 2026
- Messages
- 88
- Reaction score
- 224
- Location
- Somewhere else in Maine
- Can others edit my Photos
- Photos NOT OK to edit
They are Halloween pennant (Celithemis eponina)Nice shots
The first two are very different from any I've seen in Europe.
I had high shutter speed because I was trying to get in flight pics. Unsuccessfully might I add.Great Set. I have not seen any of these before.
Try and experiment with shutter speed. I see 1/3200 on a few of the images. If you bring that down to around 1/400 that will allow the ISO to drop down ( I am assuming you are using Auto ISO) and reduce the need for processing.
CHEERS
JBO
Photographing a Dragonfly in flight is a crossover between huge technical requirements and blind luck.I had high shutter speed because I was trying to get in flight pics. Unsuccessfully might I add.
I managed this at 1/1600 iso 400 with my G1 on the second day I tried dragonflies with my then new 45-200 zoomPhotographing a Dragonfly in flight is a crossover between huge technical requirements and blind luck.
This pic was taken with a shutter speed of 1/400:
To freeze the wings in flight would require around 1/2000. That shutter speed can only be used on very bright sunny days or with a flash that supports High Speed Sync (HSS).
That pic is one of my bucket list photos. I have hundreds of nearly perfect pics of Dragonflies in flight but only got 2 that I was totally happy with. Its a great sport that will swallow up a lot of time but when you do nail it you feel like they should give a parade in honour of your achievement.
Stick at it.
CHEERS
JBO
By the reeds by Mike Kanssen, on Flickr
Dragonfly in flight by Mike Kanssen, on Flickr
