DSLRKIT PT-04 NE Hot Shoe + Studio Strobe Flash Trigger
BestOfferBuy
Price: $16.00
  • DSLRKIT PT-04NE 4 channels Wireless Flash Trigger SET
    for Studio Strobe Flash and Hot Shoe Flash
  • Comeswith an umbrella holder,therefore there is no need to use a light stand bracket, and the flash effectiveness is the same as the item that is used with a light stand bracket.
  • Transmitter of DSLRKIT brand can trigger all the reciever as long as it is DSLRKIT brand,
  • For example: 4 Channel Transmitter can trigger the reciever from DC-01A, AC-01A, DC-02A, AC-02A, DC-04A, AC-04A, PT-04, DC-16A, AC-16A;
  • For example: 4 Channel Transmitter can trigger 16 Channel Receiver,but only work on 4 channels from the receiver(you have to find from the 16 Channel of the Receiver to see which 4 channels is work on).
Introduction
  • The brand is called DSLRKIT.
    The remote trigger for studio flashes and outdoor flash is used as the controller synchronize trigger of studio flash of cameras. It consists of a signal sender and a receiver trigger and works by means of the frequency modulation wireless remote control.
  • The signal transmitter adopts the advanced circuit and components, and can transmit the coded FM wireless signal. The circuit of the transmitter has the function of standby and hibernation, thus it has low power consumption; the products can work under the standby mode for more than one year with only one battery; continuously trigger for thirty thousand times. The trigger current is only 0.01MA, which will definitely cause no damage to the flash contact of the camera. The transmitter is applicable to the traditional or digital camera with hot shoe or PC controlling interface.
  • Receiver trigger adopts dry battery for power supply, which is safe, energy-saving, and convenient. The product adopts micro-computer for controlling the decoding, Which has superior anti-interference capability; sensitive reaction speed, the highest synchronous speed can reach 1/500 sec.
  • All the models of the product uniquely have the multi-frequency isolation technique and the self coding matching function by users. Users can freely match and use the sender and the receiver according to the demands, which have four isolated channels to suit for specific shooting environments. Triggers set in different channels can be combined to work or independently work but do not interfere with each other in an efficient distance.
  • Transmitter Receiver Power Source: 23A AC 100-230V
  • Outdoor operating distance (open area): >30M
  • Indoor operating distance: >10M
  • Frequency Channel: 4
  • Operating Frequency: 433Mhz
  • Outdoor Synchronous Speed (open area): Max 1/500sec
  • Indoor Synchronous Speed: Max 1/250sec
How to use:
• Make sure the channel selector of both transmitter and receiver are at same position
• Insert the receiver's trigger output plug into your flash's jack
• Press the test button on your transmitter. The studio light should now flash
• Insert the transmitter's hot shoe socket into your camera's hot shoe jack
• (If your camera does not have a hot shoe use a PC sync cord and insert into the socket)
• You should now be ready to start shooting
Suitable for:
  • Canon SpeedLite 580EX II, 580EX, 550EX, 540EZ, 520EZ, 430EX/EXII, 430EZ, 420EX, 420EZ, 380EX;
  • Nikon SpeedLight SB-900, SB-800, SB-600, SB-28, SB-27, SB-26, SB-25, SB-24;
  • Olympus FL-50, FL36;
  • Pentax AF-540 FGZ, AF-360 FGZ, AF-400 FT, AF-240 FT;
  • Sigma EF-500 DG Super, EF-500 DG ST, EF-430;
  • Sunpak Auto 2000DZ, 622 Pro, 433AF, 433D, 383, 355AFm 344D, 333D;
  • Vivitar 285HV (Older Vivitar 285/283 works only with PC sync);
  • Other flash models with a trigger voltage of 12V or lower;
  • Work with flash units using universal hot shoe like Nikon, Sigma, Olympus, Pentax (except Minolta SONY as they use a special hot shoe).
The transmitter of DSLRKIT brand can trigger all the reciever as long as it is DSLRKIT brand, e.g.:
  • 4 Channel Transmitter can trigger the reciever from DC-01A, AC-01A, DC-02A, AC-02A, DC-04A, AC-04A, PT-04A, DC-16A, AC-16A; 16 Channel Transmitter can trigger the reciever from DC-01A, AC-01A, DC-02A, AC-02A, DC-04A, AC-04A, PT-04A, DC-16A, AC-16A;
  • 4 Channel Transmitter can trigger 16 Channel Receiver,but only work on 4 channels from the receiver(you have to find from the 16 Channel of the Receiver to see which 4 channels is work on).
  • 16 Channel Transmitter can trigger 4 Channel Receiver,but only work on 4 channels from the transmitter(you have to find from the 16 Channel of the Transmitter to see which 4 channels is work on).
  • 4 Channel Transmitter can trigger 1 Channel Receiver,but only work on 4 channels from the receiver(you have to find from the 1 Channel of the Transmitter to see which 4 channels is work on).
  • 1 Channel Transmitter can trigger 4 Channel Receiver,but only work on 1 channels from the transmitter(you have to find from the 4 Channel of the Receiver to see which 4 channels is work on).
  • Weight: 35 g
Buy DSLRKIT PT-04 NE Hot Shoe + Studio Strobe Flash Trigger Here
New Products:
1/4 Inch Tripod screw to Tripod screw Adapter for Flash
YongNuo YN-460 II Flashes Speedlite for SONY Alpha A900 A850 A700 A77 A33 A55 A580 A560
YongNuo YN-460 Flash Speedlite for SONY Alpha, Minolta A390 A290 A550 A500 A450 A380 A330
Eviteo Air Blower Booster Power High Pressure 30kPa Black
Meike Battery Grip MK-60D for BG-E9 Canon EOS 60D D-SLR
35mm f1.7 C mount CCTV Lens for M4/3 EP1 EP2 G1 GF1 GF2 & NEX-3 NEX-5 NEX-7
3.5mm to Male FLASH PC Sync Cable Cord with Screw Lock
Meike Battery Grip MK-600D for BG-E8 Canon EOS Rebel T2i / 550D 600D
Eviteo Lens Cleaning Cloth for Digital SLR Camera DC DV PDA LCD Screen
YongNuo YN-467 E-TTL Flash Speedlight CANON 60D 50D 40D 30D 5D II 7D
camera accessories, camera bags, camera lens, digital camera accessories, camera filters
