WayneF
- Joined
- Oct 11, 2013
- Messages
- 622
- Reaction score
- 114
- Location
- Texas
- Website
- www.scantips.com
- Can others edit my Photos
- Photos OK to edit
Thanks WayneF for the explanation. Since you mentioned that the color temperature is fixable problem. I was wandering if that color shift effects white balance of the shot or it is something else and how long does it take to fix it in PS of Lightroom?
Thanks
Yes, proper white balance is the entire point, the only reason we care about light color. Any difference in actual light color and image WB setting causes incorrect color cast in the image, which needs to be corrected (for better color). This correction is quite simple to do with a white balance card, and the card is not awkward to use in a studio session.
Just to make the point extremely, for example set your digital camera to Daylight WB, and (shooting JPG), incorrectly take a picture indoors under your rooms incandescent lights (or with only the modeling lights on your studio lights). Now that intentional error is about 2500K degrees or more of red shift temperature, instead of just 400K red shift, but it shows the problem clearly. We have to make our WB setting match our actual lights.
Maybe see White Balance Correction, with or without Raw
Or really better for this purpose, see Why shoot Raw? which is about using Raw images, but which has a video you will notice (just below the top), which is in fact mostly about white balance (Raw allows easiest WB correction), under studio lights in the beginning, and later on about varied light sources. If you can hang in there a few minutes, you will see a lot about correcting WB, easily. Basically, we click the white card, and then we don't care what color the light was.
