This is going to get messy
Actually, 645 format, 72mm is the image diagonal and computed normal lens, 75mm is the closest standard lens.
For 6x6 format, 79mm is the diagonal and computed normal lens, 80mm is the standard normal lens.
For 35mm (24x36), 43mm is the diagonal and computed normal lens, but 50mm is the generally accepted normal lens.
FYI:
For 35mm film cameras (24x36 format), the "computed" normal lens is 43mm.
A^2 + B^2 = C^2, 24^2 + 36 ^2 = 1872, C = SQRT of 1872 = 43
50mm is/was the generally accepted normal lens for 35mm.
What the manufacturer puts on the camera as "normal" lens can be different than the computed normal lens.
- The normal lens was different for different manufacturers, for the same format camera.
- Olympus used a 50mm lens, and Minolta used a 55mm lens.
- The normal lens can be different for the SAME manufacturer.
- Example Nikon had 45, 50 and 58mm "normal" lenses.
So using the film diagonal as the basis for equivalent lens conversions.
43/72 = 0.60
The equivalents I come up with is close to what sparky's has. With the closest production lens being essentially the same.
55 = 33 > 35mm
145 = 87 > 85
210 = 126 > 135
