Compaq
- Joined
- Aug 29, 2010
- Messages
- 3,400
- Reaction score
- 657
- Location
- Norway
- Can others edit my Photos
- Photos OK to edit
I base this thread on this
For those that won't bother to read a rather long article, here's the the conclusions: (Chromasoft, 2009)
Any thoughts? Is exposing to the right really that effective? Not just theoretically, but in practice as well.
- "There is no advantage to image quality from ETTR that can't be duplicated by selecting a lower ISO, if a lower ISO setting is available. In some situations, such as where there is in-camera noise reduction, ETTR actually increases noise. That's what the practical tests show, and the theory of the case confirms the practical results to be correct.
- The only situation where there is an advantage to ETTR is if you're already at the lowest ISO setting your camera, and you use ETTR to synthesize a lower ISO. However, given the noise performance of most modern cameras, that advantage is often very small. The test I did here - a small sensor high pixel count camera - is the best possible scenario for seeing an improvement. Using a modern DSLR, the improvement would be marginal at best.
- Any kind of ETTR brings significant disadvantages in the shape of color and tone curve shifts that will have to be repaired in post processing. While these shifts are small, they are easily the equivalent in effect of changing profiles. So, in effect, ETTR negates the advantages that modern raw developers such as Lightroom bring with them."
