More information sooner is certainly not a bad thing.
In today's world of info-glut what counts is your ability to separate out the useful, important info from the worthless and misleading info.
You realize that the RAW file your camera creates is also an interpretation of what was actually in front of you.
No, the raw file is what the sensor actually physically records. It has it's physical limits but it is not an interpretation and most especially not a software interpretation.
The camera made an educated decision when assigning colors to each pixels.
No, a raw file is not demosaiced and individual pixel color is not yet assigned.
The picture you saw in your view finder, you will never see it exactly rendered the same.
Why do you say it is impossible to get real time WB and exposure with my EVF equipped camera ?
I didn't say that. I said you're not getting it from the EVF. I'm more concerned about exposure here than WB. A raw file has no WB, it's determined during conversion. Your EVF will show you the WB that you'll get in a camera JPEG and if you set a custom WB it will show you that.
Here's the important point: The EVF will only show you the exposure after processing. What you see in terms of exposure is the result of the camera's metering system plus the camera's software processing engine.
What is it that I'm seeing when I'm setting my WB manually and the color changes ? Or when the image gets brighter when I increase the exposure ?
If you use a preset or custom WB then the EVF is showing you that WB, but remember it has no effect whatsoever on the raw file. More importantly when you alter exposure to increase or decrease brightness you're seeing the camera's processing software's interpretation of the exposure and not what the raw file would actually record.
Is it cheating to preview our own images ?
It would be nice if you could, but the only thing you can preview is what the software in the camera is going to produce. There is no facility at this point to visually preview what the camera sensor will in fact record as a raw file.
This ultimately breaks down into: are you recording and using the raw capture capacity of your camera or are you shooting SOOC JPEGs and relying on the camera's JPEG processor. Sony cameras are equipped with Sony's Bionz image processor. The EVF in a Sony camera will show you what the Bionz processor is going to do with the sensor raw data. If you can't do any better, then the output from that Bionz processor determines the limits of what you can photograph.
With access to the raw data from the sensor in a Sony camera it's possible to do much better than the Bionz processor. In which case the info you're getting from the EVF isn't all that valuable -- it's questionable information.
Whatever the answer, I don't care, I want a good picture now. Because the moment to capture is now. WB is pretty much irrelevant since I can adjust the raw file. Exposure on the other hand, it has to be right. Or close to right.
The EVF helps with selecting your correct exposure.
Yes, exposure has to be right. And here it is:
Since the EVF shows you only what the Bionz processor thinks is the appropriate way to handle the exposure, it does not show you the actual exposure of the sensor that will be recorded in the raw file. And that's my point. Why chimp exposure based on what a collection of software algorithms spit out when it's possible to be more accurate and do a better job?
It also permits a return to manual focusing by highlighting sharp contours over the whole image. Not just at focus points. I like that too.
Let's do an example. If you have an easy shot -- easy lighting contrast and a single color (light) source, the camera processing software will do a fair job and relying on the EVF will get you both a good raw file exposure and useable JPEG. It's when the going gets tough that the photographers get separated from the fauxtographers. Here's a camera JPEG from a photo I took. This is what the software in my camera did with the photo:
This is a real high contrast image. The contrast range between the sky in the background and the water and reeds in the foreground is way beyond average. The foreground is my point of focus and my subject and I was standing on a weathered wood boardwalk. I pointed the camera at the boardwalk in front of me and pressed the AEL button to get this exposure. Looking through the EVF on a Sony A33 you'd see the above image. Would you then assess that to be a near perfect exposure? Or would you think it's overexposed and then reduce the exposure? There was a blue sky; do you see a blue sky there or is it overexposed? That exposure is just a 1/2 stop short of clipping the highlights in the raw file -- f***ing nailed it!
Standing there I of course saw the color in the sky and the thin clouds just above the horizon. You wouldn't see that in your EVF unless you reduced the exposure. But reducing the exposure would be a huge mistake. The foreground is the subject; it's the darkest part of the scene and needs as much exposure as possible. I gave it that and I would have ignored the EVF in my A33 if that's what I was using. I saw this photo and I took this photo:
I saw the color in the sky (and yes through my OVF) and I saw those thin clouds and I knew the sensor in my camera would capture those clouds and that color at the exposure I set. Your Sony EVF would have told you the sky was overexposed. I would have known better.
Joe
