Never heard of a case air what is it?I had to check back to 2016 but the model I purchased was the Toshiba 32GB FlashAir III Wireless SD Memory Card. I could not get it to successfully link to my devices no matter how diligent I was with the set up.
After a bit of research I went with the CaseAir by Tethertools. I use an iPad so I can easily send the files to my device and my iPhone if required. Additionally, the CaseAir is considerably more feature rich with remote capture and seeing the view from the camera on a much bigger screen. All of which may not be of use to you.
I have a memory card in the camera already but theres a setting on the P510 called Eyefi but you need a wifi memory card to use itI like the idea of wifi to save the connections but at the same time I like to have a physical device like a card to insert in the camera or computer to transfer files.
Case Air Wireless Tethering SystemNever heard of a case air what is it?I had to check back to 2016 but the model I purchased was the Toshiba 32GB FlashAir III Wireless SD Memory Card. I could not get it to successfully link to my devices no matter how diligent I was with the set up.
