- Joined
- Sep 2, 2005
- Messages
- 14,457
- Reaction score
- 3,329
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #16
I thought with a RAW image you could get a HDR image with just one exposure... As in, the software would then make the up/down exposures for you... Am I right?
-Fauzi
No, if you can get the light range in one exposure there is no need for HDR. One can tonemap that image with is not the same. Taking one proper exposure in RAW and then making more than one file is still not HDR. It is again, tonemapping.
HDR is used when the light range is too broad for one exposure; meaning one needs details in the highlights and detail in the shadows, which the current cameras cannot support.
Both of you need to re-read what I said. Ann, he is technically correct.
Since high is a relative term and not an objective definition, I could argue I have a high dynamic range image even if I turn on the dynamic lighting control on my Nikon... or even if my sensor happens to be slightly higher dynamic range than yours. Some people call single-shot-RAW "HDRs" EDRs... Extended Dynamic Range.
The point is that, technically correct or not, they're not going to get as much dynamic range out of an image with one exposure as they would with 2, 3 or more... so if it's HDR you want to do, then choosing to do it with one image is going to net you a fairly lousy HDR.
If you're going to do it, do it well.
