First HDR with the Sony NEX 6
vipgraphx
Some Where In the Desert
So got a sony NEX 6 late last night, charged the battery and hit the sack. This morning I went out and took a quick test HDR of this tractor. Not to bad, still have to get it use to the controls.
First impressions, I was quite impressed with image quality. Very sharp images thus far. I did manually adjust the exposures because the auto bracket in this camera is .3ev So I shot three exposures at -2,0,+2. I can see this becoming a potential problem for me at least as I am used to the nikon system with a timer set to do them all. With my d700 I was able to do these very very fast with the grip which is ideal for sunset and preventing ghosting in the sun. If I have to take the time to adjust each exposure in these instances I will lose the placement of the sun causing an oval shape. Not a horrible problem but a potential problem, we will have to see.
The other problem I had is that I am running photoshop CS5 on a MAC and I had to download the Adobe DNG image converter to convert sonys RAW files. Camera RAW in photoshop does not want to open up those files. SO this could also be a potential problem when doing many photos. Photomatix did not like those sony raw files at all turned everything pink........???? IF I chose to upgrade to PhotoShop CC it does open up these sony files without the converter but I like the older camera raw better. Once again not a horrible issue but could be time consuming as I am adding that extra step.
So far that is it for now..I will continue to test this camera out if this does not work out I am going to give the Nikon D7100 a world.
tractor by VIPGraphX, on Flickr
Aperture 2 won't open my nex files, but aperture 3 does, so I would imagine a newer photoshop would also support the files.
I have the nex 7, but they updated exposure bracketing and I can do +-3 ev. I would imagine the 6 can do the same since it was released later, but maybe the setup is different.
On the 7, I scroll through the shooting menu (self timer, continuous, then it says brk) when I have that selected down below it my soft key turns into "option" 2select there I can choose .3, .7, 1, 2, or ,3. EV. Maybe that will help?
The only bummer is that you have to press the shutter three times, so a remote might be something worth investing In! They are only like 6$ on amazon. I'm not sure why they haven't updated that feature yet.
You can hold down the shutter and it will do all three continuously.
To bad they could not just put an auto timer like the nikons
I know!! And the technology is in there since the self timer can take 3 shots, so it would just be a simple software update. I'm surprised Trey Ratcliff hasn't requested it. He seems to always get what he wants from sony when he asks ;-)
Yeah maybe in the near future if they don't put all their focus on their mirror less full frames.
