Bitter Jeweler
- Joined
- Apr 27, 2009
- Messages
- 12,983
- Reaction score
- 5,003
- Location
- Cleveland, Ohio
- Can others edit my Photos
- Photos OK to edit
After my last attempt, which was a little flat, I went out and got another speedlight, and trigger. Everytime I add something new to the mix, it feels like the first time.
I am also trying to decide if I like shots on white, or on black.
Shot with 1 flash below paper and one above. The below flash was set higher power than the above. The upper flash partially hit the white paper roof, and a reflector card in front. My lightbox is just a small folded paper box.
This was shot on glass, above black velvet. One flash directly down on the roof, the other firing in from the side, again partially hitting the paper box, and partially hitting a reflector card.
The making of the above ring. The tool is called a milgrain tool, which has little concave cups on a small wheel, you roll this wheel, pressing with all your might, to leave the beaded, millgrain impression.
All shot with Canon 100mm f/2.8 Macro
