Judge Sharpe
- Joined
- Feb 13, 2008
- Messages
- 307
- Reaction score
- 0
- Location
- birmingham alabama usa
- Can others edit my Photos
- Photos OK to edit
In reading the various post, I have become confused as to the problem. Is it:
1. That the focusing screen and the film plane do not match up so that when you have an indication of focus in the view finder, the film is out of focus?
2. That the view finder and the film are both in focus but the distance indication at Infinity is off for use on a particular body?
If the view finder and film are not both in focus at the same time, the first thing I would check is the doppler adjustment. Is it adjusted for your particular eyesight? +1, 0 or -1. If that is OK then I would find a focus target and shoot a roll of BW film, fine grain. Set the target at a known measured distance from the film plan ( this is usually indicated on the camera body.) and record the settings as you shoot through the distance indicators. If one distance is off, the others should be off by a proportionate amount. You should get softness at five feet and at infinity, providing the lens does not have an internal problem.
If the problem is that focus is good on the view screen and the film, but the problem is the distance indicator, carefully calibrate the lens for the body you are using by making reference marks on the lens.
The film plane should be the same for all cameras that interchangeably use the same lenses. I do not think that the use of a digital caliper will accurately measure a potential difference. The way to compare is with a calibration target to establish differing points of sharpest focus.
Having a shop preform these checks should not be costly, a repain might be.
Judge Sharpe
Judge Sharpe
