JBPhotog
- Joined
- Mar 26, 2018
- Messages
- 931
- Reaction score
- 433
- Location
- Canada
- Can others edit my Photos
- Photos NOT OK to edit
FYI, just came across this on Nikon's website.
"D-SLR's require a "tip positive" sync connection to an external strobe units. On some external strobe units the sync polarity is easy to change because they use the "household" type plug. If the strobes do not fire, simply turn the plug around and insert it with the male pin connectors in the other holes. Other types of connectors (such as the standard "phono" plug) are not generally changeable by the user.
Warning: Negative voltages or voltages over 250 V applied to the camera's sync terminal could not only prevent normal operation, but may damage the sync circuit of the camera or flash. Check with the strobe manufacturer for voltage specifications."
