AMOMENT
- Joined
- Sep 27, 2011
- Messages
- 701
- Reaction score
- 48
- Location
- NY
- Can others edit my Photos
- Photos OK to edit
Is it true that if I use an auto select focus point other than the center one, that it is more likely that less of my photo will be in focus even with the same DOF calculation? (because of cross points?)
Someone had recommended using my center focus point to focus, and then recomposing so that the person's eye was in focus in th right positon. Usually, if your subject is in the center of a frame (given that's how you want the composition), then to completely nail the eye, you would have to select a focus point slightly left or right. Right? If I select my central point, depress to do so, and then move my camera at all it will be out of focus. So, how is that I should most often use my center point if I want to nail the focus on someone's eye?
I can't read my manual because I don't have it anymore. It got lost during a move. I'm sure I can order a new one but until then, maybe you guys can help since you know so much.
This whole focusing and then recomposing is confusing me. To compose a shot you need to depress the shutter to lock focus. If you move the camera or the subject moves at all, unless you are using tracking, then your subject will be out of focus. I'm frustrated. I know there is alot I should be reading and I'm working on getting the books. I really appreciate everyone's time in explaining. I know this is all basic stuff to you but I am just starting.
