Gold, or Silver... or White!
SabrinaO
I'm talking about reflectors here! When is it good to use which? I remember reading in a magazine (or a site?)that said certain situations call for a specific reflector. I wish I knew where I read it. Anyways, I was playing around with my reflectors the other day and the gold side casted a warm glow. The white side casted a white light. I didn't use the silver yet.
But I think this is how each one it works... please correct me or explain if im wrong
-If im outside and there is a blue overcast or shady area... use the gold reflector
-If a person is really pale use a gold reflector
-Use a silver reflector if i want to cast silvery pearlized highlights
Are these correct? What are some other instances?
Anyone use a reflector?
I have yet to try mine, however for what I understood, white is for softer light than silver (less harsh reflection, more diffusion).
In only very general terms, yes.
Maybe. It depends on how you want the shot to turn out and what your main light source(s) is.
Maybe. It depends on how you want the shot to turn out and what your main light source(s) is. I would probably use 2 reflectors 1 gold, one white, both lighting the same portion of the subject. You may also want to consider using a black reflector to subtract light.
You can use 2 or more reflector colors at the same time in all the above situations: white/gold, gold/silver, gold/white, gold/white/silver, and don't forget the uses for the black reflector.
