Green Screens ?
JayClark79
Delaware
Where do you get the images that you put in the background of shots when a green screen is used???
Could be anything. Using your own shots would be cheap & easy...or you could by from stock sites etc.
For most still photography applications, you really don't need a green (or blue etc) screen. You just have to make sure that your subject doesn't blend into whatever background you do have. This can almost always be done with careful lighting.
The colored 'ChromaKey' backgrounds can actually make things harder because they might bounce some of their color back onto your subjects.
hey mike thanks for the responce... im looking at buying a home background kit... i was going to get just the black back ground and a white back ground and was wondering how difficult it was to change the image on the green screen without making the people in the portrait look like they were cut out and placed there..
but while your here lol..what size background do you recommend for a home studio... is the 10x20 going to be way to big and hardly used...or is a 10x5 more practical... im in the basement as well and space is not really an issue.... what size is your home background?
I was going to start a thread today based on Green Screens / Chromakey. I have a green screen background and have been experimenting with it a little.
Are there any tips out there as to lighting the background not to get any bleeding into the hair on subjects or the halo around the subject?
What type of lighting on the background have you guys been using? Brighter light or more subtle light? Special process like using 2/3 lights just for the background or ?????
I see alot of potential for using green screens because of the options with Photoshop and the various backgrounds without having to go out on location.
Any tips, please share!!!!
Besides my own shots that can be used for backgrounds, I picked up a package of all kinds of backgrounds from ebay:
COMPLETE DIGITAL BACKGROUNDS FOR USE WITH GREEN SCREEN - eBay (item 190306601450 end time Nov-05-09 22:33:23 PST)
Besides the disk they sent, they provided access to download anything and everything from their web site for 30 days, which was long enough for me to grab everything they had. All told, I got 1,987 backgrounds and templates to use for about $25. They're large, high quality, and actually quite nice. They take up 9.93 gigs on my hard drive.
nice buckster... do you have some examples of green screen shots... how easy is it to change to the new image?
Get your subject as far away from it as possible.
I've found that it doesn't really matter much, as long as you:
A. Get a good separation between the subject and background.
B. light the background evenly, especially around the subject.
Associated with that, I'll echo Mike - any color will work fine for still photography, as long as you follow A and B above. Chroma Green works well because people aren't that color so it's easy to select. People ain't pure white or pure black either though, so... yeah...
If you're going to really get into this, do yourself a favor and get onOne Mask Pro. It's worth every penny.
There are ways to make it easier or more difficult...but your skill with PS will play a big part.
Firstly, it will look best if you match your lighting to the background that you are using. It would obvious look stupid if the subject was light from the right, while the whole background had light coming from the left.
Also, some things/parts of a subject are easier or harder to cut out (extract). For example, a dude wearing a hat would be relatively easy....but a girl with a big teased out 80's hair style might be a nightmare to extract from a background.
The important part is that your subject doesn't blend into the background...and the less the background peeks through your subject, the better.
As for background size...that depends on how you use it. A 10x20 background is typically used to cover the back 'wall' as well as the floor of the shooting area. Sometimes that is preferable. Other times, you may just want the backdrop to be the back wall and not the floor.
Either way, a larger background is probably better...because it sucks when your backdrop isn't long enough.
It also sucks when it's not wide enough...but if you are shooting in a basement, your width might be already limited.
Thanks for the suggestions mike... my wifes gonna kill me i just ordered a whole set up for my basement lol... i didnt get the green screen though ill save that for christmas lol
How far is far? Are we talking about 6' like most photos or are we moving to 10', 15', ?????
I'll take a look into that program that you suggested. Also, thanks for another website to get backgrounds. I've already got a little more than 800 backgrounds.
I'd really like to learn alot more about this (2) images together setup. I've been learning ways to blur the background on a graduated scale to create depth, but that halo is still killing me.
So basically, a (1) light setup might work then with a background reflector like normally used for a background light.
After perfecting this skill, I'm sure more lights would be needed to evenly light a subject standing up full body. Have you guys shot someone full length and extracted them completely? For example, have you guys been able to extract a subject and put them standing on a beach?
I'd really love to see some examples to get my mind wrapped a little more around this concept. Examples are always good as I try to imagine what you guys did and try to set this as an example and replicate it.
Regards,
If you have room to get 10 or 15 feet, go for it. The point is not to have light bouncing off a bright green background and lighting up your subject from behind with that color, influencing the hair and other edge detail. Inverse square law comes into play here - you need enough distance for it to fall off sufficiently so as not to influence your subject.
You'll find excellent examples of extracting full length body shots there. I don't have anything handy to post right now that specifically used a green screen (I might pull one out of the files later and put up a side-by side), but it's not like it's a big mystery to extract a background and stick another one in it's place. It's the blending of edge, light and shadow work that makes it believable or not.
I'll agree with the extraction. I've already created an "Action" in PS to extract the background. My only concern from the start has been the edge as you mentioned.
Also, in the past, I didn't practice lighting the background separately for an easier extraction and even lighting. The edge situation has been my nightmare. The reason I ask for an example is to look at the edges and the finer detail of maybe hair or the little spaces that would maybe give me a problem. I've tried feathering the edges and contracting the edges, but still come up with the green.
I'll have to work on this 10-15' separation distance. I usually work within close quarters, but I'm sure I can setup something different to try atleast 8' and see if it changes anything from what I'm currently getting.
I picked up some seamless paper (Savage) from BHPhoto for $44. It's almost 9' x 12 yards(36'). Savage | 107" x 12yds Background Paper | 46-12 | B&H Photo
Do I need something brighter than this or will it suffice? It's only a solid color and I'm not photographing aliens.
That background, like all backgrounds, can be as bright or as dark as you want it to be. One of the neat things about photography and light is that you can turn a black background white, or a white background black, or anything in between. Then throw a colored gel over whatever light source you're using for that background, and you've got yourself any color you want, in any intensity you want, limited only by the gel colors you have.
Guys, green screen is great for video -- or if you don't know what your final background is going to be -- or if you can't quite predict what your subject's colors will be...
I've had much better success choosing a background color that blends well with the intended superimposed background.
For a still shot, you just have to isolate 1 frame -- so you can do this easily regardless of the background color, just as long as it is distinct from the subject.
Alright so here it goes... I own an entertainment agency and we are starting to explore the professional photography realm - which we all know very little about. We would like to start doing GreenScreen/ChromaKey photography. After hours of youtubing, I have devised a list of products and methods to start our Green Screen endeavor and was wondering if anyone had any ideas, tips, corrections, advice, etc. on the subject.
We're thinking about using...
an EEFX.com Foam-Backed green backdrop
a QL1000 series 3 part lighting kit with softboxes
...should we use softboxes? or should we use umbrellas?
...do we need a flash trigger? or can we get away with keeping the lights on the whole time?
2 pairs of Home Depot type halogen work lights to light the backdrop behind the subject
and Photoshop (ACS 4) for the editing part
a Canon 50D for the actual photography
...anyone recommend another camera? or another lens?
Thanks!
