ssnxp
- Joined
- Oct 18, 2009
- Messages
- 104
- Reaction score
- 0
- Location
- California
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
well i figured i would try my hand at PP. here's what i came up with without it being too overly proccessed
Thanks! That came out pretty good.
#1 You cut off her foot and leg and you also chose to have her head in the middle of the frame.
#2 has similar issues in that she is really tight on the left side, cut off on the frame and you cut off her left leg.
#3 is better, you didn't cut off any major body parts, but you left alot of head room on top of her head. Get in closer. You also seem to have missed the focus, she seems blurry
#4 probably the better composed shot, she fills up the frame decently and you have her body in a way that angles are shaped and formed.
When you say with flash, what flash are you using? Your popup flash or an actual mounted flash? If using a mounted flash, look into bouncing the flash off walls and ceilings so you arent just blasting her head on (such as you did in photo 1).
You can try properly exposing for the background, set the mounted flash to TTL (or adjust exposure manually) and use your flash to fill in the light.
Read up on strobist info Strobist: Lighting 101 to get a better idea of how flash and lights work.
Thanks! I bookmarked the link. I'm currently using my popup flash (still saving for that 580exII, just bought a nifty fifty though!).
I've been a bit confused about TTL vs E-TTL. What I get is that TTL does NOT use pre-flashes, and E-TTL does, correct? I've googled it, but most articles go into how TTL and E-TTL works and why, and they don't really clarify the differences for a complete noob. I ask, because in some settings I'd really like to NOT have pre-flashes.
Is it possible to use an external flash without pre-flashes, through the AF beam (infrared?) on the 580exII, or is that AF assist beam for something completely different?
And thanks for all the replies so far!
