Halos when using flash
Onerider
Cumberland Plateau, Tennessee Misplaced Texan
Hello all,
I've been practicing with the flash and have noticed faint yellow haze or halos behind these. My background is 4 ft. away. I can't figure why this is happening.
This is SOOC. Any ideas?
http://
Nice shot. As far as the halos go, I can't really see too much in the posted image, so questions. Are you using the flash at full power? It may be that the halos are caused by flashback, or a direct reflection, from the flowers themselves. Have you tried shooting these with the flash at a lower power, say 50% and see if you still have this problem? I have a small Lastolite soft box that measures about 5.5 x 6 inches. I use that with my flash when I am taking some of my flower pictures. This softens the light and I have never seen this problem when using it. I almost always have my flash off the camera for shots like this one, so are you using the flash on the camera or is it off the camera so that it is hitting the flowers at an angle to the camera? Just some things to think about. Hope this helps.
WesternGuy
I too use flash off camera and the same Lastolite softbox on Flowers. Never see any halos. But I must admit I don't see much here either.
Thanks for the ideas. The flash was off camera with a home made snoot grid. 1/250 @ f/4 1/64 flash. I have noticed this at other flash settings also. I'm using a 17-50 lens at 50mm. I wonder if I need to back away a little. I' about 3 feet or so away from the flower.
