HDMI to SDI rig converters for D3300
HDMI to SDI Cable will not work there is no cable that will convert HDMI to SDI. HDMI is a parallel digital signal interface while SDI signals are serial and you will need an electronic converter device.
So I am assuming you are looking for something some what portable? Since the converter you have needs 5v DC and 4 watts I would look at a portable power brick something like this https://chargetech.com/product/port...ecutter&utm_medium=referral&utm_campaign=twc1 This should have no problem powering the camera side converter.
Another option is to use a product by Atomos, they are a portable recorder/monitor and they have a battery powered converter Connect - Atomos HDMI IN and SDI out.
