vipgraphx
- Joined
- Dec 1, 2011
- Messages
- 2,415
- Reaction score
- 440
- Location
- Some Where In the Desert
- Can others edit my Photos
- Photos OK to edit
Here is a video tutorial I created for another method I use for HDR processing. This is done with photomatix, photoshop cs5, nik color effex and topaz denoise.
I really recommend these programs. Photomatix is about $100 Denoise is about $80 and nik color effex is $200. Well worth the money if you are going to be processing a lot of HDR. I have downloaded and tried many others but these are the ones that I use all the time and like the workflow better. You can find discount codes that saves you up to 15% online for all these software choices.
The video goes pretty quick because I had to adjust the frame rate to fit it in under 10 min. I recomend viewing in the largest scale. I have another posting on here where it is a written tutorial and is basically the same minus the extra vivid and shadow map processed images from photomatix.
I hope this helps some of you new to HDR
OOOOPS....... I WONDER WHERE I WOULD BE WITHOUT YOUR HELP!
