- Joined
- May 16, 2007
- Messages
- 961
- Reaction score
- 11
- Can others edit my Photos
- Photos OK to edit
Ok you are set with all you need.Now play with it and remember to keep it simple to start with.
Use just one subject (for simplicity).
It will be hard to get a pure white background without backlight so i would X that out.
Stand your subject close to the paper backdrop if you want the light color that you were going after
Put a strobe with reflector (6"funnel thingy) and barn doors on a boom stand. Position it so it is above (out of camera view) and almost touching the paper, aimed close to straight down but forward a tad, now the barn door should be up on the backside so that it lets the light spill in an inverted v across the backdrop. Flag the other door down to control this as your hair light AND keep it from creating lens flare.
Placement will be tricky, just the right spot will yield the background you want and double as a hair light
Use the modeling light to help in placement and get this light nailed in place before the subject enters the set.
Now stand or sit the subject so that the barn door flaged side of the hair light just hits the backside of the hair, again placement of subject will be tricky.
Tip~ You can angle this setup to make it look more natural as with the sun (our brain like to see light as if the sun made it)
Phewwww. Now you have a hair light with spill to light the backdrop
Main light, I would choose the beauty dish (22 or so inch) and grid it.
Put it on a stand with wheels and counterweight at bottom if you got it.
Up high about 9 feet aim it down at angle so the nose shadow looks good
This light should sorta graze the subject .
Hope this helps.
D.E.
Hope this helps.
D.E.
