My kids are in marching band and play soccer. My 55-200mm lens on my Nikon D5000 is just not reaching out far enough. Should I buy yet another lens for my Nikon or should I just get the Panasonic FZ200 that reaches out to 600mm. We are talking roughly the same money!! The Panasonic would be a good all around camera for taking on vacations when I don't want to lug around the DSLR and several lenses.......but........is there a big difference in the digital zoom getting me out to 600mm and the 300mm Nikon lens? I am absolutely a novice and will never have the time to put into venturing too much into the manual features of my D5000. I just can't make the call with the knowledge that I have. Thanks for any and all suggestions!!
Is there a big difference in zoom range, no. The FZ200 does have an equivalent 600 mm zoom, however it's max image size is quite a bit smaller than the image size you get from the D5000, so if you take an image from the D5000 and reduce the image size to 1/2 the original size, then copy the original sized image into this new, smaller frame you get basically the exact same effect as the image the FZ200 produces, so really the 600 mm zoom isn't any better than the 300 mm on your DSLR.
The FZ200 does have that nice F/2.8 which is pretty sweet, just be aware that the lowlight on even the FZ200 is terrible compared to a DSLR. You can't really get usable pictures above ISO800, and even 800 gets pretty grainy. Also the much smaller sensor makes it so the FZ200 just really isn't all that great in low light conditions. Better than most bridge cameras by a little bit, but nothing compared to DSLR.
It is smaller and light weight, and the EVF unlike many is actually pretty usable. Like most bridge cameras you do have a burst fire mode that will allow you to take a few frames pretty quickly, but once it hits that max burst the camera pretty much slows down to a crawl so shooting action can take some getting used to and again it's not quite on par with the DSLR's capabilities in this regard.
But if your doing landscapes and portraits and such and you don't really need the lowlight capabilities it's a nice little camera to have in the bag. Image quality is pretty good, again not on par with a DSLR but if your not doing large prints (anything much over say 8 1/2 x 11) then most likely it will be acceptable for you.
