HELP! Venturing into product photography!
sbower363
Marysville CA
So I just started working for a company that wants to get their business website up and running and they want me to photograph all of their products. Me having no experience in product photography is making me feel a little lost and overwhelmed. The products that I'm photographing are mostly glass I looked online at some ways to create things like ezcubes and I made one but not sure if I made it right. I attached the picture of the cube i created.
Also I know what kinds of bulbs to use (30 watt trumpet top bulb 5000 kelvins CFL daylight) but not sure what the best most inexpensive set up would be? I was thinking about just going to walmart or hardware store and buying desktop lamps and putting them around the box? But I'm not sure any tips would be appreciated! Thank you!
WOW...desk lamps are not going to light glassware....you may have bitten off more than you can chew. Lighting glassware is not easy and something you can learn in a paragraph or two.
Does anyone have any advice maybe personal problems you yourself have run into that may help me? Listen maybe I did bite off more then I can chew but what I am I supposed to do give up and pull out all my hair lol I have to try right?
Yes. You should give it a try.
No. It is not easy and it would take a lot of typing to try and give you even basic information.
Get and read the book. It will tell you a lot of what it is you want to know.
It is discouraging that the photo you did post is badly under exposed. Apparently you don't yet understand the basic fundamentals of using available light.
Understanding Digital Camera Histograms: Tones and Contrast
Understanding Digital Camera Histograms: Luminosity and Color
You will need a tripod and constant lights that have output equivalent to about 200 watts each, because the walls of your lightbox will absorb/reflect a fair amount of light.
For lighting glass, you will likely also want to subtract light from parts of the scene. Subtracting light is often done with pieces of strategically placed black foam board.
Light color temperature can be adjusted post process in a Raw converter if you make the originals as Raw image data files.
Lighting for Product Photography: The Digital Photographer's Step-by-Step Guide to Sculpting with Light
You will need a tripod and constant lights that have output equivalent to about 200 watts each.
Lighting for Product Photography: The Digital Photographer's Step-by-Step Guide to Sculpting with Light[/QUOTE
The photo I posted was taken by a iphone3 and I took it very fast cause I'm actually not supposed to have my phone at work lol. I actually am familiar with basic photography wouldn't say I'm super familiar because I have only taken one photography class I am a graphic designer actually but photography is a hobby I like mixing the two. Everything I do is usually outside in the sunlight so working with lighting is pretty foreign to me. I am familiar with raw that's all I shoot in. I have created the black bounce boards (sorry if that's the wrong term lol) anyway I definitely am going to get that book and thank you for the link I will read them and refresh my memory.
One question I do have though is am I on the right track with the box I created? And if not what modifications could be made?
Btw do u know of any good sites to check out for studio lighting?
Hey sbower363,
I totally understand how frustrating shooing glass can be. When I used to photograph artwork, and before I had really figured it out, I had to struggle and struggle through it. BUT, I did learn quite a few helpful tips and am happy to pass them on to you.
Tip #1: Indirect Lighting Set up #1: Gradient Background - This will create a glowing effect.
To accomplish this, follow these steps:
Step 1: Set up a sweeping white or grey background.
Step 2. Place black reflectors on either side of the glass product (sandwich it).
Step 3: Set up your light (can be spotlight, or diffused light) to shine onto the background onto a spot about 6 inches behind the product.
Step 4: Expose your image correctly and remove imperfections with an editing program like Photoshop.
Tip #2: Indirect Lighting Set up #2: Black Background - This will make the product appear to be outlines in white light, while the middle of the glass product will be black. Sort of see-through.
Step 1: Set up product on a small black table or surface. If you use a shiny tabletop, this will add a nice professional look. For example, you could use black plexi, or a sheet of glass with black construction paper underneath it.
Step 2: Set up a large diffused softbox (larger than the product at least) behind this table.
Step 3: Set up a black background to hang right in front of the large softbox - this creates the background for the image and acts as a "go-between" between the light and the product.
Step 4: Set up two black reflectors on either side of the product.
Step 5: Set up another softbox at a low level directly in front of the product to light any labels on the products.
Tip #3: Lighting Tent: White Background - Since you already have one!
Step 1: Place objects in the tent, on a stable surface.
Step 2: If possible, evenly light each side of the tent: Top, Back, Side 1, Side 2, and front (to light the label). If you have a limited amount of lighting, use a large window during a bright time of day to light the back, and use a large white reflector for fill light in the front and above.
Step 3: Insert black reflector boards (you can easily make these if you don't have them - think kid's art project!) into the back corners of the tent, behind or to the sides of the product. This will bounce black onto the glass to give it definition from the background.
After you shoot, pump up contrast and brightness as necessary in post-production. This will give a professional edge!
Well, I hope this has served you a little bit and made things a bit easier! Let me know if it has, and how your attempts turn out! You can connect with me back at my website too: Katie Nixon Photography | Commercial Food + Product + Still Life - Food
Good luck!
Copnstant lighting is going to work for you on this. You can easily find any type of light to use as long as you know how to do a custom white balance on your camera. Being as it is product photography you have the advantage of not having to stop action so you can use long shutter speeds as long as you are working off of a rock solid tripod set up. Then you start to tinker with modifying and moving the lights, even around a light tent like you built here. You may find you need to get/make some flat black inserts to put in your light tent as every reflective surface is going to want to reflect the white back at you. Another useful thing to have is a piece of colored plexi-glass to set your object on and work with reflections of it.
Also, watch out for self portraits in the reflections of glass, you might also have to set up the camera shooting through a mask to keep those out too.
Start playing.... for something like this at the level you are starting at you don't need expensive strobes and fancy set ups. There are plenty of tips and tutorials on the internet. Google and YouTube aregreat tools to use and find all kinds of help, under both search the term "product photography". YOu will be reading and watching for a long time trying to figure out which tips will work for your skill level and budget.
