Help with noise
tecboy
San Jose, Cali, The Heart of Silicon Valley
I recently bought 5Dm3,and I'm having problem with noise shooting inside the low lighting room. Tips on how to improve these images?
tips for shooting in low light or tips for noise reduction?
what lenses are you using? any with IS so you can shoot at lower shutter speeds?
camera settings?
what software are you using? what NR techniques? (I just move the slider for the most part)
I find LR's noise reduction to be pretty good. just got the free NIK package which has Dfine for NR. haven't tried it yet.
I have EF 24-105mm f/4, thx.
I like auto ISO. I usually set mine to max at 3200. everything else is manual.
even if you need ISO 6400, its better to shoot at ISO6400 if it gets you proper exposure than to underexpose and have to bring it up almost a stop in post. 5DIII should handle high ISO as good as anything else really.
you may have some noise at those ISO levels, but hopefully nothing a little LR wont easily fix without too much softening.
darker areas show noise the worst.
noise looks perfectly reasonable for the situation and ISO you were at...
if you have a problem with the noise in those images, next time: put your camera on a tripod, kill all your subjects, strap their dead bodies into chairs, and take the picture at 100 ISO with a 5 second shutter.
Well, an organizer has a crop sensor with f/1.4 lens. His photos look much cleaner than mine.
Were these resized photos you posted. The file size is pretty small.
EXIF for the 1st photo. I left off the Name portion.
Camera: Canon EOS 5D Mark III
Lens: EF24-105mm f/4L IS USM
Shot at 105 mm
Exposure: Auto exposure, Shutter priority AE, 1/125 sec, f/4.5, ISO 6400, Compensation: +5/3
Flash: Off, Did not fire
Date: March 28, 2016 11:23:54AM (timezone not specified)
(21 hours, 11 minutes, 58 seconds ago, assuming image timezone of US Pacific)
File: 1,564 × 1,278 JPEG (2.0 megapixels)
1,690,670 bytes (1.6 megabytes)
Color Encoding: Embedded color profile: “sRGB”
You're shooting at 6400 and F/4.5.
f/1.4 is just over three stops of light. So at the same shutter speed, your organizer can be shooting at 800 ISO.
800 ISO on a crop body is going to probably look a lot better than 6400 on your 5D. The glass could also be better as well and improve IQ.
I think your shots look fine as far as IQ goes, especially when reduced in viewing size. MUCH better than the recent Bernie Sanders shots that popped up over the weekend.
