ON1 Photo Raw 2026 versus DXO Photolab 10
Montana
I use both ON1 Photo Raw 2026 versus DXO Photolab 10.
They have many similar features, but here is my take on significant differences:
DxO’s philosophy is to enhance image purity, not change or add/remove objects.
DXO has excellent noise reduction (the best?) which I often need for low-light, moving subjects.
It has better masking with the ability to refine a mask via chroma and luminance.
ON1 has a broader philosophy and allows for use of multiple images
via layering, bracketing, HDR, panoramas, etc.
ON1 also allows edits to a photograph that would not be allowed in most contests:
generative erase, sky replacement, resize AI, etc.
ON1 has a broader suite of presets and effects.
I find ON1's AI based noise reduction good, but not as good as DXO.
I find ON1's masking good, but not as good as DXO.
I’m looking for reliable information about daily prayer schedules in Bahrain. It would be helpful to have accurate timings that are easy to check each day. I usually search for prayer time Isa Town when planning my daily prayers. Having the timings for Fajr, Dhuhr, Asr, Maghrib, and Isha in one place is convenient. Accurate local timings also make it easier to plan work and other activities.
I think that’s a fair assessment. DxO’s biggest strength is image quality, particularly its noise reduction and masking, while ON1 offers much more flexibility for creative editing and combining multiple images. For high ISO or low light photography, I’d lean toward DxO because its noise reduction and detail preservation are excellent. For photographers who want layers, HDR, panoramas, AI tools, presets, and effects in one application, ON1 is probably the better choice. Using both also makes sense. DxO can handle the initial RAW processing and noise reduction, while ON1 can be used afterward for more creative or complex edits.
I really dislike ON1's interface, which I find very confusing.
DXO is great and will do everything I want most of the time. (I never want to do any of the AI stuff!)
For the things DXO won't do (layers, multiple images, text etc) I use Pixelmator Pro or Affinity.
That’s a useful comparison because it sounds like the real difference is less about which program has more features and more about what you want the final image to be. If the priority is keeping the original scene intact while getting the cleanest possible file, DxO’s approach makes a lot of sense. Noise reduction is especially important for high-ISO shots, and having strong masking and control over luminance and chroma can save a lot of time on difficult images.
ON1 seems more attractive when the goal is to actually build or reshape an image rather than simply develop the original capture. Layers, HDR, panoramas, sky replacement and generative tools make it a much broader all-in-one environment. The presets and effects are another advantage if you like experimenting rather than doing the same type of correction on every image.
I also think the contest point is worth keeping in mind. There’s a big difference between photographic processing and creating a composite or manipulated image, and what is acceptable depends entirely on the rules of the particular competition. A tool being available doesn't necessarily mean the resulting image qualifies as an unaltered photograph.
For my workflow, I’d probably use the two programs for different jobs rather than trying to make one replace the other. DxO would be the place to get the RAW file as clean as possible, particularly with difficult high-ISO images, while ON1 would make more sense when I want layers, creative effects or more extensive editing. Having both available is probably more useful than arguing over which one is universally better.
I'm an Adobe/Topaz guy mainly because I'm just too invested in the system and am too lazy to try anything else. Use what works for you.
This matches how I see the two as well. DxO for clean, natural processing and ON1 when you want more creative options.
DXO and Afinity just announced they now work together with the native file now, you don't have to flatten into a tiff any more to go from DXO into Afinity. That opens up manipulation outside of DXO now.
I was also going to mention the integration of DXO and Affinity. I find I prefer DXO for the reasons mentioned above. Their initial processing of raw photo and their superb noise reduction feature is my goto. I am used to Photoshop's layers and masking, but generally I find I am learning and beginning to master the masking features of both DXO and Affinity. The current smooth integration-transfer of a DXO fine with Affinity is very convenient. I can layer images, make a composit, and perform most adjustments with Affinity. ON1 used to be my goto, but have found DXO preferable. Likewise, On1 used to be my goto for their enlarging algorithm, but now find Gigapixal produces a better result. So, that is my 2 cents as I become acquainted with this forum.
