mrstravis
- Joined
- Jul 12, 2011
- Messages
- 271
- Reaction score
- 12
- Location
- VA
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
pgriz said:As noted above, the moon is lit by the same light source as we are during the day - so use noon-time exposure values. Next, being far away, you don't need a high f/stop for depth of field, as the moon is effectively at infinity anyways. However, most lenses are not at their sharpest at either extreme of aperture, so pick an aperture that is maybe two stops away from wide-open. If you have live view, use it to focus (ie, no autofocus). Also, set your exposure manually, as the camera will be seeing a bright spot surrounded by darkness, and will try to get everything 18% grey. Even the histogram doesn't help here (much). So the drill is: camera on tripod to minimize movement and camera shake, ISO at native (100 for Canon, 200 for Nikon), focus manually using live-view if you have it, use the sunny 16 rule as a point of departure. So at ISO 100, that would be about 1/800sec at f/5.6. If the moon is too dark, reduce your shutter speed.
A bright spot, that's exactly what I saw! It was a bit frustrating. Thank you for your help!
