How do I get rid of these shadows?
rwilliams
I have a LOT to learn about outdoor photography & getting the lighting right, so excuse me if this is a dumb question. In this picture, how would I have gotten rid of the shadow behind her on the blanket? I tried to adjust here where the sun wasn't causing bad shadows on her face, but I couldn't figure out any way to prevent the shadows behind her. Would a simple reflector solve this problem or do I need some other type of light?
In that pic it would probably be pretty easy to clone out as well.
you could also use a white sheet in place of blue tarp if you just want to soften the shadows..
What if there is no shade available?
Shoot in the shade............
You make your own shade.
5-in-1 reflectors have 2 slip covers that have a different color reflector on each side - silver, black, sunlight, white.
Those slip covers go over a diffusion panel that is the body of the device.
The diffusion panel is partially transparent (it's a fine mesh screen) and lets some sunlight thorough.
That's what I plan on doing, but I would so much rather have it right straight out the camera.
The shadow bed info the baby is not distracting. The Dutch tilt making the baby look like she is going to fall over however is distracting.
You can turn on the flash and use it for "fill". It won't completely eliminate the shadow but it will substantially weaken it (you'll have a soft shadow.)
You do want some shadows. Good "light" is based on having good "shadows". Shadows provide the 3-dimensional feel in an image. If there are no shadows at all then the image will look flat.
Take the picture 180 degrees from where you took it, and then get down on the babies level.
Thanks, I straightened it out when I finished editing it :)
I honestly don't think the shadow looks unnatural, but you could simply lighten it in Photoshop. In this attempt, I selective curves and an action called paint with light.$Retouched.webp
