How do you meter for flash if you dont have a flash meter?
ababysean
Pensacola, FL
or are there less expensive models to use? Like old versions with less features? I can NOT spend 200 bucks right now but I'd really like to try some of the off camera flash I saw from the lasolite tutorials.
Do you just eye ball it off the back of your lcd? with your highlights and histogram?
any tips appreciated.
I am in the same boat as you and am just starting to get into using OCF. After some research and practice it ended up not being as complicated or crazy as I thought. I think you can eyeball it fairly easily though I am sure we haven't been getting amazing results yet. Some trial and error and practice and you will start getting a better feeling for things. Good luck!
Strobist: Guide Number: Your Free Flash Meter
That will usually get you pretty close.
The guide numbers in my flash manual (SB-600) were all for ISO100 and the lowest I can set my camera is ISO200, so what I did was convert the whole grid to ISO200 (by multiplying all the values by 1.4) and printing myself up a little cheat sheet that I keep in the camera bag. So I just figure out what f/stop I want to be at, how far the flash is from the subject, multiply those numbers, multiply that by 1.5 it if I'm using a shoot-through umbrella or bouncing it, and find that number on the chart. That math is all basic enough to do in my head, and a couple test shots later, I'm dialed in.
After a while it starts to get easier to come up with a best-guess without even looking at the chart though.
Basic math to the rescue! :thumbup: ;)
GN = distance × f-number
A little basic algebra lets you solve for any of the 3 parameters.
Life is a math word problem.
http://www.nikonusa.com/pdf/manuals/Speedlights/SB-600.pdf
page 35
ok I am reading the manual about guide number and settings but I am so confused.
If anyone could help me out...
Say I have a subject 15 feet from the flash. I want to use F4, and ISO 200.
I see where it says to find the guild number, but I am just confused on what to do and why??
If I can not do i-ttl with the trigger that I have, I need to put the camera in manual mode.
So then, what?
I just don't get it.
You can work w/ Guide numbers but lucky w/ digital you can also take a test shot, and readjust.
On average shoot, when I'm using both lights, since I know what they can do already, my ocf is sb800 at 1/4 power on iso 400.
Well, knowing how to use the guide numbers will at least reduce the number of test shots you have to do.
I wouldn't want to be standing there in front of clients going "Hold on ... I just have to do a couple more test shots..."
One you get it dialed in, when you shoot next time with a similar setup, you pretty much know where to start, and maybe 2 or 3 test shots is all you need.
You can use guess work ,but once you have it set tie a piece of string to your flash and stretch it out to your models nose tie a knot, now you can move your flash up down where ever you want as long as the knot touches the models nose the exposure should be ok (in a studio)
Its about experience, thats why have to practice practice practice.
I've never used guide number.
Back in film, OCF was about the same power as on-camera and 1/3 way b/n on-camera and subject. 160 asa 220 film at 1/125 & f/8.
Today w/ digital, On-camera in ttl and ocf at 1/4 power(if ISO 400, and 1/8 if ISO 800) 30-45degrees cam right/left and about 1/3 b/n camera and subject. All it'll do is add dimensionality and give me a ratio.
Your flash has a guide number of 138 at ISO200, full power. To get the f/stop, you divide the guide number by the distance in feet. So 138/15 = 9.2 . This means that if your flash was 15 ft. away from your subject you'd need an f/stop of f/9. However, if you want to shoot at f/4, then you divide the guide number by the f/stop to get the distance. So 138/4 give you a distance of 34.5 ft. This means that to shoot at f/4, full power, head directed at subject, your flash should be at a distance of 34.5 ft.
