How to get a nice sharp crisp Photo?
Same way you sight in a rifle, you have to shoot, shoot, and shoot some more. Then you need to make adjustments. Get a good SLR with coupons. Then repeat the process over again for the rest of your life. Thats what i have got so far atleast, I'm new as well.
:thumbup:
That is the best tutorial I have read so far, there are quite a few though.
Good luck.
I am also kind of a newb at this. It sounds like it just takes a lot of practice like a lot of things. I guess that's what ya pay for all those years of experience when you get a photographer.
don't EVER depend on PS or any other software to "sharpen" the focus on your photos. Yes, they can sharpen, but then as you print the picture in bigger sizes (starting at 8x10) you'll be able to tell and it looks HORRIBLE.
Learn to get it right in camera so you don't have to sharpen in PS. Knowing how to use photoshop will NOT make you a professional photographer... Just sayin'.
Yeah, and I am just saying......horsesh*t.
True you should do the best you can in camera, but RAW files need sharpening in most cases, and digital images are almost always sharpened for the net, and especially for print, using post processing. You would be hard pressed to find a professional photo unprocessed, whether its by the photog or some editor at a magazine. Shooting in JPEG has your camera sharpening in camera. As for print sizes, that is why you size before sharpening for print. Perhaps you also should spend some time learning about PP before doling out half @ssed advice.......just sayin.
Okay, so it was wrong for me to point out that you shouldn't depend on software to make your pictures perfect? And it was wrong for me to point out that just because you know how to use photoshop, it doesn't make you a professional photographer... Really? Did you click the link to the website in my siggy? Because I'm definitely not an idiot. I think I know how to "process" my images.
I was simply stating that you shouldn't depend on photoshop or any other software to make your photos look good and that knowing how to use photoshop or other editing software doesn't make you a pro... I'm not a pro, but I'm certainly not an idiot either. Thanks, have a nice day :)
Good lens, tripod, focus, mirror lock up, remote shutter = tack sharp.
kind of a noob question but what exactly is mirror lock up feature, i think ive seen it on my older nikon before and never really understood it.
Make sure you are using the focus points correctly. When possible, as others said, use mirror lockup ( or live view ) and a tripod. If handheld, try to use the reciprocal or faster of the focal length.( dont forget to factor your cameras crop factor. So for a 300mm lens you would probably want to be close to 1/500th or faster. For 50mm probably around 1/80th or faster. This helps minimize camera shake. Also, get rid of any cheap filters you may have on the camera and make sure you dont have the in camera noise reduction cranked to the max, this can cause loss of sharpness although if you have alot of noise, you need to look into why and try to avoid it if possible.
thanks
Noone called you an idiot. I just pointed out that you gave bad advice, and in a fairly condescending way. Photoshop is not some voodoo devil, its a tool that should be embraced and used correctly in addition to everything else in your arsenal. I have given bad advice before and been called out on it. Take your lumps and move on. I just didnt want a noob walking away thinking that photoshop or post processing in general is bad.
I can't view your website on my phone, but saw your flickr. I am not one to put down someones work, but I think everyone can learn more though...including me...and including you.
it is very difficult to tell something about sharpness on such a small size: details are of course lost.
Anyway, it seems like you did not focus on the face, but perhaps in some place below. Before activating mirror lock, tripod, and so, better to concentrate on basic focusing. I do not know which kind of camera you have, but if you are using automating focus point selection, disable it, focus on the center and then recompose.
Because of the anti-aliasing (AA, or low-pass) filter in a digital camera you have to sharpen pretty much every digital image. In other words, you can't get it completely right in the camera.
The mistake most people make when sharpening is not understanding what sharpening does.
Consequently, they use the wrong sharpening parameters and/or the wrong sharpening technique for the intended use of the image.
I always chuckle when I see someone has made a photo using very shallow depth-of-field to blur the background, and then globally sharpened the entire photo.
I 100% Depend on software to make my pictures perfect. I shoot RAW and I need to PP my images to complete them.
I also think your coming off a little rude tbh. And the last bolded portion of your reply sounds really cocky.
To the OP, are you using autofocus or manual?
:thumbdown:
Get over yourself.
You can get tack sharp images hand held as well. Just sayin'.
Agreed. I forgot to mention to turn off the VR/IS when using a tripod.
The camera basically locks the mirror up when you press the shutter button or remote shutter prior to taking the exposure. You press the shutter again and it takes the pictures. On a tripod, VR off, shutter remote, mirror lock up = 0 movement = sharp.
Same way you sight in a rifle, you have to shoot, shoot, and shoot some more. Then you need to make adjustments. Then repeat the process over again for the rest of your life. Thats what i have got so far atleast, I'm new as well.
:thumbup:
Camera Exposure: Aperture, ISO & Shutter Speed
Good luck.
Interesting analogy. Thanks.
