How to remove transparent background?
Jmesparza05
Riverside, CA
So I want to remove the transparent background and only have Superman 2 text saved, is that possible in gimp 2.10? Or any other free softwares
The first question to ask is
What are the copyright issues. Do you have the right to copy, is it royalty free.
Confusing question... how do you remove something that's not there? :stung:
On the other hand, open in any basic editor, like Irfanview, save as a JPG. Now it will have a background.
Well, technically there is something there. There are background pixels, they are just being rendered transparent.
If I understand the OP, they want to have an image with only the stylized text, and not the (transparent) bounding rectangle. I’m not sure if that can be done as a saved file.
If you are using photoshop i would start by making the image its own layer by right clicking the layer the design is on and selecting layer from background.
this will turn the image into a normal layer.
next i would add a layer and drag it under the previous layer
on that layer press ctrl or Alt + Delete to fill the layer with the currently selected colour
and then you have a background so it is just a case of exporting it and the layer will come with it.
hope that helps
i do also think it will be a similar process in photo pea
hope that helps
I used a different image and figured it out
