Can anyone give some tips on using a gray card. I have a Canon 40d, I have been trying to take some product shots on a white back ground and they are coming out under exposed.
Any help would be great
Meter with the strobes. Yes, they may indeed alter the color balance, and that's really the point.Im curious too on how to use a gray card. Do you meter the gray card with or without the strobes you are gonna be using? Wont the flash alter the 18% gray color?
The gray card is an anchor on equal values of the color wheel. If the strobes shift the color in some direction, we can bring it back to equal again because of the gray card, which we know should be equal, eliminating that color shift.
That's the white balance part of using a gray card.
The 18% (or 12%, depending on how persnickity you want to get) part of using a gray card is that's the standard anchor on a "normal" diffused value in terms of reflected light - which just happens to also be the standard anchor that light meters are tuned to (this is where the 12% comes in, which is half a stop lighter than 18%).
In any case, it works particularly well to get a proper diffused value of caucasion skin tones. If you're shooting portraits of caucasions, this will get you in the ballpark of a correct diffused exposure value for the skin, if not nail it. For lighter or darker skin, you may need to adjust accordingly - it's a starting point. For more extreme examples, if you're shooting snow or coal, you'll need a lot more compensation to nail the exposure and not lose details via over or under exposure.
So, it does both: white balance AND exposure balance, when used properly.
Yeah, and today's in-camera meters do a good job with that, so it's not much fuss. Still, since I'm usually setting up the lights and color balance and all with a gray card anyway before I park my subject in front of the lens, why not get the diffused value too while I'm at it?Meter with the strobes. Yes, they may indeed alter the color balance, and that's really the point.Im curious too on how to use a gray card. Do you meter the gray card with or without the strobes you are gonna be using? Wont the flash alter the 18% gray color?
huh......i never heard of a grey card used for metering.....guess I learned something today, although I would still prefer to meter my subject.
Would that be reflective or incident metering?.... although I would still prefer to meter my subject.
