PixelRabbit
A naughty little bunny...
- Joined
- Nov 28, 2011
- Messages
- 6,593
- Reaction score
- 3,719
- Location
- Ontario
- Can others edit my Photos
- Photos NOT OK to edit
^^ Right. Sometimes difficult to see, but pay attention to the corners as you line up. The lower right is a little blown out. Aside from those nitpicks, it's a very nice graphic image - your lines are very strong. :thumbup: A perfect square would set it off well.you just needed to change angle slightly to make it symetrical
You actually bring up an interesting point and I agree. I'm torn when I do this kind of shot, I mean there has to be a bazillion shots out there of hydro lines (insert any cliche/overdone subject in place of the lines, waterdrops, moon, brick wall etc...) and I can with confidence say that the very shot I posted already exists.amolitor said:You can always tell the canucks with their "hydro"!
I do like this minimalist abstract stuff, and this is a nice example of why I like it, and why I quite dislike it (even when I do it). It's graphically strong, a very visually muscular image (whatever that means) interesting to look at, rewarding to the patient viewer. Ultimately, though, it winds up being more or less a technical exercise in line and form, which doesn't say much.
This is a very fine example of the form, though, make no mistake. It is the form, not the image, that I both love and dislike![]()
I agree, I think it is the slight differences that keep my eye traveling around the image, comparing point to point, I like that about the shot.unpopular said:I like the slight asymmetry, I think if it were perfectly symmetrical the image would be more about symmetry than line and form.
Thanks Designer, I went through many possible crops on this one and I think that this was the strongest but I do see what you mean, I`m not sure there really is a crop that will ground it without taking away the balance between tower and lines.
Here is an export of it sooc, thoughts?
Wanna hear something funny Designer?
Part of the reason I cropped the bottom/other towers in the distance off is the tower caught in the base of the big one was too asymmetrical and sticking out on the right hand side![]()
