I shot this of my lil girl. Pleae CC
Most people just edit until it looks good. You won't have to edit much if you get it right in camera. Under exposing then brightening or raising exposure in post can cause noise so it's best to get exposure right in camera.
Cute little girl. The softening is way too much IMO. It looks OOF because of it.
I think it looks good but she kind of blends with the background too much.
yeah its pretty common to do too much luminance. look at your photo at 100% or full crop and adjust the luminance till it looks good, then back it off a tiny bit so you see just a little bit of pixalization, if this make sense. cause remember your not looking at the picture at 100% ever, unless your printing posters. and when you look at it zoomed out at 25% or so the noise/pixalization goes away, but if you added too much luminanace its going to look too soft.
A portrait orientation would have been SO much better. Try to get her stand a little further away from the background too as the foliage is distracting. bear in mind that just getting a nice Bokeh (soft background) is not usually enough. if you can still make out the form of what is behind, it will still be distracting.
kchapman0304 said:
Whats the best way to warm her skin tone up?!
What editing program are you using?
It's a good basic image to start with.
I warmed it up a bit, increased exposure, set the black level, applied a medium to high contrast curve and sharpened it:
Adorable little girl! In terms of the background would adjusting FOV so the background is softer than the subject help?? (n00b question)
Raw or Jpeg? You can go to open as - choose your file then at the bottom of the dialogue box change file type drop down box to camera raw. This will let you open a Jpeg in camera raw. The temperature slider (goes from blue to yellow) will warn up the image if you slide towards yellow.
In photoshop you could use a warming filter. There are many different ways to do it....
I shoot both. But i do open as- and do camera raw. I will go try that thank you! Thanks MLeek. I will try to do that and see what I can come up with. If its anything near what yours looks like?!
