In a slump
really like the first one the others are good but could do with a larger aperture as i would like to see more of the fly in focus
A larger aperture will reduce DOF, not increase it.
Shooting with a flash will only provide so much light.... trying to increase DOF by closing the aperture can only be countered by an increase in ISO.
when i say larger aperture i mean a larger number say like f22 to give a wider DOF appose to say f2.8 to give a narrow DOF.
Don't get in a slump fellow Tyler, just remember... YOLO!
The photo issues seem to already be addressed; as for the slump, most of us can completely identify. It happens. I was in one pretty much all last month, maybe the end of March too. Usually, when I get in slumps, I have a variety of things I do that often help me "snap out of it." This time, nothing worked and I finally just had to put the camera down for about two weeks or so.
Then I got an awesome new lens. That took care of the slump. :D But I really hope the next slump doesn't require a $1K chunk of glass as a remedy. :lmao:
Some of the things that *normally* work for me:
--Just putting the camera down for a day or two. Still LOOK for the shots, but don't take any.
--Take pictures of something you don't usually do. If you're mostly into portraits, do some landscapes...or water drops...or abstracts. If you do a lot of nature stuff, try something else that is completely "out of the box" for you. Doesn't really matter if it's good, bad, or so-so, just makes you THINK differently.
--Use a different lens. I shoot 99% of the time with either my 70-300 (well, NOW, with my 150-500) or my 100mm macro. But if I'm in a funk, I might put the 50mm on or the 18-55 kit lens and shoot just with that lens for a day or two. Find anything I can and make it as interesting as I can, just using that one lens.
--Do one of those "10 Things within 10 feet" type challenges. Or shoot only green things, or red things.
ALL of that is about getting out of my "normal" way of thinking about photography. That usually helps me to come back with a fresh view when I do my "normal" stuff again.
..... But I really hope the next slump doesn't require a $1K chunk of glass as a remedy. :lmao:.........
Send me $1,000. I'll send you half a pair of broken eyeglasses.
I'll sell you both halves for $1899.
That would be confusing to a lot of people. F/22 is smaller than f/2.8, both physically and mathematically.
thats just the way i was taught to read it as 22 is a larger number then 2.8 so to me a larger aperture would be the larger number value, this is just my way of doing it, its not a wrong way of doing it everyone has there own preference
The thing is though it actually is wrong unfortunately.
i think you will find its not wrong, its just my choice of term its like calling something a nick name and lots of photographers i know down my way use this terminology don't like it don't bother replying 7 years of photography learning from a various professional photographers, i know the teqnical terms and i chose not to use them. this is my choice and your opinion is not going to change that.
just because i chose to call it one thing when someone else choses to call it something different does not mean i'm wrong it doesn't matter how you get somewhere as long as you get there.
i get the same results by calling f22 a larger aperture then f2.8 as you do by calling f22 a smaller aperture then f2.8 i want a wider DOF i would use a f22 you want a wider DOF you would you f22 i want a shallow DOF i would use f2.8 you want a shallow DOF you would use f2.8
i call it larger becase its a larger number you call it smaller because the space the light allowed to go through is smaller
Dude. It's wrong. You're wrong, your photographer friends are wrong, and your logic is wrong. I hate to be so blunt, but this is a very basic photographic concept.
Tell me which is a larger number:
Fifty divided by two
Or
Fifty divided by twenty two
Aperture numbers are a fraction. F standing for focal length.
You have a focal length of 50mm, your aperture is at f/2. Divide 50 by 2 and you get 25mm. That is the diameter of your aperture diaphragm when it contracts during the exposure. F/22 is not larger, it's not a larger number. It's a smaller number and citing otherwise is incorrect.
