iPhone 6s photos I have taken
jmann8686
Washington state
Well this is the only camera I have and here are some photos I have taken recently.
#1
#2
#3
#4
Peeb
Semi-automatic Mediocrity Generator
Supporting Member
Oklahoma
Likey has been clicked.
KenC
Philadelphia
In the "Welcome" thread I said to post photos and now I see you already have.
These are good. The one I like most is the second, which elicits a feeling of abandonment from that car - it almost seems like a portrait in a way. The one of the tractor is not as good because the lighting is uninteresting and there's a little too much in the foreground. Back to the second, the only thing I might change if this were mine is to crop just a bit on the right to eliminate the bright spot on the hood that is on the edge of the frame and maybe part of that other bright spot on the corner of the roof. If you wanted to maintain the square crop, which seems to work for this, you could shave just a bit off the top and the bottom.
The last one works well as a square crop also - nice color contrast between the blue and the yellow.
OP
jmann8686
jmann8686
Washington state
So I cropped the photo of the Hudson.
#5
And here is a different angle of the tractor.
#6
OP
jmann8686
jmann8686
Washington state
Designer
Iowa
I think the best one here is #3 (see why you need to number them?) for composition and good use of color.
OP
jmann8686
jmann8686
Washington state
Thank you. I went back and numbered them. I will keep that in mind as I post more.
JohnSw
So how do you like using the camera on your iPhone 6s?
OP
jmann8686
jmann8686
Washington state
I like it. I don't use the camera app on the phone I use procam app when I am taking photos.
Sent from my iPhone using Tapatalk
OP
jmann8686
jmann8686
Washington state
#7. Took this this morning
#8 with a little editing.
