IR filter not compatible with Canon kit lens
looimaster
I'd like to buy IR filter but I just noticed that some people say that it's not complatible with some lenses. Here's the list:
NOT COMPATIBLE:
Canon EF 15mm f/2.8 fisheye
Canon EF 16-35mm f/2.8 L
Canon EF-S 18-55mm f/3.5-5.6
Canon EF 20mm f/2.8
Canon EF 20-35mm f/3.5-4.5 USM
Canon EF 24-85mm f/3.5-4.5
Canon EF 28-70mm f/2.8 L
Canon EF 28-105mm f/3.5-4.5
Canon EF 35mm f/2
Canon EF 35-80mm f/4-5.6
Canon EF 50mm f/1.4
Canon EF 50mm f/2.5 Macro
Canon EF 70-200mm f/2.8 L IS
Canon EF 70-300mm f/4.5-5.6 DO
Canon EF 85mm f/1.8
Tamron 17-35mm
Tamron 19-35mm
Tamron 70-300mm Macro
Tokina 12-24mm
COMPATIBLE:
Canon EF-S 10-22mm f/3.5-4.5
Canon EF 17-40mm f/4 L
Canon EF-S 17-85 f/4-5.6 IS USM
Canon EF 22-55mm f/4-5.6 USM
Canon TS-E 24mm f/3.5L
Canon EF 24-70mm f/2.8 L
Canon EF 28-135mm/3.5-5.6 IS
Canon EF 28mm f/2.8
Canon EF 50mm f/1.8 MKI
Canon EF 50mm f/1.8 MKII
Canon EF 70-200mm f/4 L
Canon EF 70-300mm f/4-5.6 IS
Canon EF 75-300mm f/4-5.6 IS
Canon EF 100-400mm f/4-5.6 L IS
Canon EF 100mm f/2.8 Macro
Canon EF 135mm f/2 L
MTO 500mm f/8
Sigma 400mm f/5.6
Tamron 28-300mm XR
They say that some "hotspot" appears when you shot it with incompatible lenses. Is that ture? Better IR filter would work with these lenses or not? Which one should I buy?
That doesn't make any sense to me, as far as I'm aware any filter will be 'compatible' with any lens provided you buy the right filter thread size. The canon 18-55 has a 58mm filter thread.
Note that the IR filters you buy like that are not really that good - they block any light that is not IR, but your camera has a built in 'low-pass' filter that block only IR light, meaning that you need ultra long exposures in order to let enough IR light through the lens filter so that enough of it can still get through the internal low-pass filter. These filters still work, but just be aware that you're going to typically need 30sec - 2 minute exposures for a landscape type shot. Obviously, portraits are out of the question.
I found that information for 58mm filter that costs $10. Seller describes it as incompatible with some lenses due to "hotspots" that appear on photos. They say that it's due to lens' structure and it cannot be corrected in camera.
I bet it's due to poor filter and poor manufacturer (Massa company). Am I right? Which IR filter would you buy to avoid that? I'm going to use it for 50mm f/1.8 II lens as well as kit lens.
